I'd put the S4 calipers on the shelf until I was ready to change the fronts as well.
Even the pre S models have excellent brakes, upgrading on a street car makes no sense to me. |
A quick check of rear rotors on ebay 1979 -85 289mm high, 20mm thick !985-95 299mm high, 23.9mm thick also from memory the spacer required to centre the callipers was around 3mm |
http://forums.pelicanparts.com/uploa...1423344208.jpg |
There's more to braking than being able to "lock up the tires." Hell, even drum brakes will "lock up the tires" - at least once before they fade to nothing. There is also brake feel, control, and yes, heat management. Upgrading to S4 or better brakes is one of the most worthwhile improvements you can make on an early car - whether you drive it on the track or not. There is nothing particularly bad about the brakes on the early cars, the 4 piston Brembos just work better. James |
James |
I agree, they look WAY better. I have s4 brakes on my car. Yes, Porsche keeps upgrading the brakes, you have to do something to justify price increases and match the other cars you're competing against. If you want to spend the time and money for a different feel going to the quicky mart that's fine. I don't agree they "work better" unless your threshold braking on the street. I've done the upgrade, there's no real difference other than appeal. But back to the OP doing half the upgrade, especially just the rears IMO is a BAD idea.
Porsche upgrades to sell new cars to current customers, its called marketing. The newest models also weigh hundreds of pounds more and have a higher top speed. Make repeated stops from 15 mph faster than an early model will go and yes, you could use new brakes. |
Thankyou all for your information!
It in very interesting to hear different points of view. I have the rear brembos ready to go, and have sorced a full front set-up at the right price. Just waiting for the guy to get to a point where the car doesn't need to be mobile My shocks are the adjustable type, so looks like I may be able to keep them! I will still change the rears first though, just to get mobile, and just take it fairly easy. I'm sure I'll soon feel any problems under braking, if the system is badly compromised! |
Do it properly first time, trial and error can go badly wrong.:eek:
http://forums.pelicanparts.com/uploa...1423513913.jpg |
One of the beauties of the 928, that car was hit really hard in the rear, but look at the doors, most likely they still open and close, no damage to the people areas (my sympathy as always for any in the back seats).
Maybe I'll do all 4 corners at the same time!!!!![emoji33]
Sent from my iPad using Tapatalk |
If you want to play with your brakes, there is nothing stopping you.
[QUOTE=Danglerb If you want to play with your brakes, there is nothing stopping you Don't need brakes, just point it at a tree. |
About 10 years ago I was rear-ended by a Ford Contour while stopped at a red light.
The Ford was probably doing about 20 mph at the time of impact. Both doors were pinched shut - I had to crawl out through the window. Repair estimate was $21,322.09! (loved that .09).http://forums.pelicanparts.com/uploa...1423581193.jpg |
Looks like a tweak running down from the B pillar, sign of a 928 being toast.
OTOH you are still around. |
Bought it back from my Insurance Co. for salvage value - too good a car to through away.
I had a friend with a frame shop. Told him to do the initial pulls and then we'd decide where to go - either track beast or street car. Turns out the rear suspension points were not tweaked. After my frame guy did his magic, all it needed was new bumper shocks, cover, tailights, some finish body work, a new paint job and lots of time and TLC. Car & I live on to this day. |
| All times are GMT -8. The time now is 02:02 PM. |
