87 S4. Motor out. things to do?
Hey all,
Finally getting to the 928, while working a resurrection of the 968.
928= Engine is out.
Going to do:
Intake refresh, MM, OPG, Steering rack rebuild, TB/WP with new Cam gears, Injectors to Witch Hunter, Powder coat.
Questions for today. The While your in there items. Specifically, with the oil pan down.
I got the Cam covers, Fuel Rails off with no issues. Hope my good fortune continues.
I will most likely do suspension items, wiring harness rebuild.
thnx
John
Old 04-14-2015, 11:30 AM
Network Native
Danglerb's Avatar
Use extreme caution with the powder coat. Too many people get a great looking powder coat with a tiny bit of abrasive "glued" someplace inside the intake, and few months later the bit comes loose and the engine is toast.
Depending on age and history I might consider replacing a lot of thing that are hard to do with engine in.
Old 04-14-2015, 04:25 PM
Thnx,
Never mind, Thrust bearing is waaaaaayyyyyy out. Engine is toast!!
Old 04-15-2015, 05:25 PM
