thrust bearing issue
Hi All
Can some one please clarify.
If the crank thrust bearing needs replacing, is it a straight forward job or does the crank need to be removed to do it. I going to look at a 928 this morning with the interest to buy and just want some knowledge. I will get round to buying a workshop manual eventually.
Ive replaced them years ago on old British cars and it was as simple as removing the bearing cap and spin the old one out and spin the new one in.
Regards
Old 04-20-2015, 01:06 AM
Pete R's Avatar
You could possibly do rod bearings with out crank removal but to do the main bearings (of which the trust bearing is one, you have to split the block and remove the crankshaft.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 04-20-2015, 05:02 AM
JK McDonald's Avatar
Thrust Bearing -
Hey Runningman - I hope we haven't scared you off from buying a 928 with some of our precautions and warnings of things to look out for. There are lots of good ones around when you have a heads-up of what to look for. The 928 Porsche thrust bearing problem is only an issue on an engine that has not had a simple crankshaft end play check during it's routine maintenance. It is most often the result of a previous non-informed or uncaring owner.
Although it is recommended that the associated pinch/bolt coupler/adjustment-crank shaft check be part of any pre-purchase inspection, it's the later (higher HP) model cars that are most often found with the thrust bearing problem. Both my 1984 and 1985 were fine even though I suspect that this potential problem area had never been checked on either car. Since the problem is torque related it is the slippage or creep of the pinch coupler that allows the drive shaft to lengthen slightly against the flex-plate and push the crank shaft against the internal thrust bearing. If caught before there is any damage, there are several easy solutions that will fix the problem including a newer design for the pinch coupler.
Here is good explanation and over view: http://members.rennlist.com/v1uhoh/928TechFlexPlatearticleTH.pdf
Good Luck with your search, Michael
1984 928S - "Miss Purdy"
1987 911SC - "Frau Helga"
1986 930 - "Well Hung"
1975 911 Targa "Blue"
Old 04-20-2015, 02:36 PM
stepson's Avatar
1984 was the last year that used spacers and a circlip on the end of the TT to prevent Thrust Bearing migration. I don't believe that I've ever heard of Thrust bearing failure on a 1984 engine with the spacers and circlip intact. After 1984, the spacers, the circlip and the groove in the TT that held the circlip were discontinued and Thrust bearing failure began showing up. I often wondered why the circlip/spacer combination couldn't be retrofitted to the later cars.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 04-20-2015, 03:25 PM
Horse Power - Torque - Design Change -
Hey Stepson, I agree with you in the torque tube/drive shaft design and thrust bearing issues. I have also noticed that MOST cars didn't began seeing any serious thrust bearing problems until the later models (928 S4) with their horse power around the 300+ hp range. Like you mentioned - this is when the deadly combination of HP/Torque/Pinch Coupler/Drive Shaft Design = Thrust Bearing Failure - changes came together.
Luckily I bought both my 928's from mild mannered, milk toast, drive it only on warm sunny days at a safe and sane 55 mph owners......
Michael
Old 04-20-2015, 04:30 PM
harborman's Avatar
I own a 86' 928S but never checked the thrust bearing on it. The car has 68K original miles. It had 37K when I bought it 5 years ago. I am rather conservative driving it, no burn outs! I wonder if it is necessary to do the thrust check.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 04-21-2015, 05:28 AM
Petie3rd
Mrmerlin's Avatar
Harborman yes check the thrust bearing clearance,
and also re torque the rear , then the front pinch bolts,
after you recenter the driveshaft.
tighten the bolts to 66 ft/lbs with a some blue loctite on the bolt threads
Old 04-21-2015, 05:44 AM
stepson's Avatar
Michael
Michael,
Don't forget that the EuroS 928s also generated 300 HP all the way back to 1980. Since the circlip/spacer design was abandoned after 1984, any 928 from 1985 on, or any 928 that has had the circlip/spacer disturbed should be checked for crankshaft endplay. Better to be safe than sorry in my book.
Old 04-21-2015, 09:07 AM
