Why was it put in storage? What was done to prepare it for storage? Always good to make contact with other local owners. |
Well, the new fan kit from FF Dynamics is installed, and I'm not that happy with it. First off the fan motor made an awful racket. They did send me a replacement fairly fast. I went to get it all mounted today with this aluminum shroud, and the upper plastic shroud will not fit right with it. I'm going to have to do some trimming I guess. I was hoping it would just all go together for an "extreme fan kit" for $325. I expected better. As soon as I get the shroud figured out I will trim all the wires up and make it all pretty. Just a bit frustrated with it to be honest. I'm not overheating anymore though, so that is good. I'll come back to this setup later. I'm going to contact them once I have it all finished and see if they can make a few changes and write some real instructions. The paperwork that came with the system was not great, and disjointed.
I also got the wiring cleaned up and fixed for the oil pressure sender, and the alternator. I put on the new alternator rear cover and cooling hose, as well as new foam and screws for the drivers side splash guard. While I had the alternator out I did the fuel sender o-ring, and the larger o-ring up above it as well. Pretty good day of fixing. http://forums.pelicanparts.com/uploa...1433999696.jpg http://forums.pelicanparts.com/uploa...1433999735.jpg Blue wire is for an LED which I'll get to later, and green is for A/C on. I have no A/C currently and I'll get it hooked up later. http://forums.pelicanparts.com/uploa...1433999780.jpg http://forums.pelicanparts.com/uploa...1433999816.jpg Note the scratching from the aluminum shroud hitting the plastic. I'll have to trim, or figure out a different way to mount it. http://forums.pelicanparts.com/uploa...1433999854.jpg http://forums.pelicanparts.com/uploa...1433999892.jpg http://forums.pelicanparts.com/uploa...1433999941.jpg http://forums.pelicanparts.com/uploa...1433999999.jpg http://forums.pelicanparts.com/uploa...1434000036.jpg http://forums.pelicanparts.com/uploa...1434000705.jpg |
