I need to replace the underhood insulation on my 85S. I am not sure of the best way to do this. any ideas? best tools to use? etc. etc.
Remove the hood (mark the hinges first). Use PB Blaster to remove the glue. Then clean well. There are several places you can buy a replacement hood liner. I bought mine from some shop here in Michigan, it was made of some aircraft foam and you could get a Porsche logo if you wish. I used contact cement from Lowes to stick the new liner on. Believe it or not, the PB Blaster does cut the stock glue, it works! The contact cement is used for counter top laminate. You might be able to do this with the hood on, but much better to remove it and place on a nice padded table to remove, clean and apply the new hood liner.
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires. Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster |
Present: 1984 928S/Indischrot, 1994 968/Polar Silver Past: 1979 911SC Targa/Petrol Blue |
Absolutely, there's more than one way to do it. I just remembered that Dwayne had documented his approach.
I understand 928s R Us has the original waffle pattern pad available and I think it's self stick. Hugo
I forget the place I bought mine from, but it was a Leather Shop here in Michigan, He has custom cut liners made of aircraft material. I would go with this instead of the stock product. This is it: classic9leathershop.com
+1 on calling Robb Budd at Classic 9. His product is superior to stock OEM IMHO.
Plus, he's a real nice guy.
John Curry (Drift King) 928OC member Grand Prix White 1994 GTS AT (The GTS) Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz) |
thanx guys. so helpful. will look into classic 9. 85 928s 51000 mi.
