-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Lifting Points (http://forums.pelicanparts.com/porsche-928-technical-forum/866937-lifting-points.html)
928gene928 05-26-2015 11:07 AM
Lifting Points
Just wondered if anybody knew the distance between the two lifting points on the side of the 928. I have a "Quick Jack" assembly which uses two separate hydraulic scissor lift assemblies. They use rubber blocks on the top surface for lifting the vehicle.
Been too lazy to get under the car to take a measurement. Want to make a pin type assemble to fit into the lifting points.
Awaino 05-26-2015 12:03 PM
Just buy a set of these...
Liftbars
Danglerb 05-27-2015 10:35 AM
Not sure on distance, but the shape of the lift point thing is different depending on model year.
