'84 928 Water Pump Replacement
I'm thinking of replacing my timing belt along with tensioners and water pump. The price for water pumps are all over the map starting from $80 to an astounding $700 for a Lasso. They all appear physically the same in photos with metal impellers but what can account for such a vast price spread, are the more expensive pumps worth it? Thank you for your responses.
Old 09-10-2015, 07:41 PM
stepson's Avatar
The Lasos should have a plastic impeller and a special sleeve to prevent shaft/impeller migration. The others? I don't know.
But.... the only Laso pump still available I believe, is the the pump for the older cars, which is another thing altogether since the older pump can used on the newer engines wiht the installation of the Porkension'r.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 09-11-2015, 01:09 AM
harborman's Avatar
When I did the TB and pump job 4 years ago I paid $350 for a new Laso pump with plastic impeller. I probably could have left the original pump in since the car only had 37K miles, but I did it anyway.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 09-11-2015, 06:28 AM
stepson's Avatar
I did Timing belt jobs on 3 of my cars this year. I replaced water pumps on 2 of the cars since there was a failure of that component on those cars, and resealed the oil pumps and replaced the front main seal on all 3. The GTS had a Porsche water pump on it that had no play in the shaft and spun freely, so I did not replace it while doing the timing belt. 3 months later, the water pump shaft seal dumped all the coolant out on the garage floor one morning when I started it.(It was a bad morning)
I'm not saying to replace the water pump every timing belt job, but just relaying my experience. I probably won't replace the water pumps on these 3 cars on my next timing belt replacement, but I sure as heck will look very closely at them.
I believe the Laso pumps for the older cars with the plastic impeller can still be had for under $500.
Old 09-15-2015, 09:45 AM
I see some pumps are available for +/- $50. I would rather play in a basket of drunken rattlesnakes than install one of those on my 928. Stick with Lasso from one of our sponsoring vendors...pick one who knows 928's well and will talk to you about the process...
1956 Intermeccanica 356 Speedster (sold),1957 Intermeccanica 356 Speedster (sold),,1985.5 Porsche 944 (sold),1955 Thunder Ranch 550 Spyder (sold), 1955 Outlaw 356 Speedster (currently in build out), 1984 Porsche 928S (White), 1984 Porsche 928S (Red)
Old 09-16-2015, 04:57 AM
