-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Starting issue after engine is warm (http://forums.pelicanparts.com/porsche-928-technical-forum/872029-starting-issue-after-engine-warm.html)
milspam 06-24-2015 01:24 PM
SmileWavyI know I've seen this problem posted before, but can't find it. Porsche 928s euro starts fine when cold, but difficult to start after driving around for a bit. Any suggestions? Any help on where to start would be appreciated. Thanks
JhwShark 06-24-2015 04:49 PM
You don't give much details.
A general known issue is a failing/failed Fuel Accumulator will cause a warm no-start condition.
Danglerb 06-25-2015 10:06 AM
Every model year had both US and Euro models, and lots change by model year.
Early CIS car nothing like L or LH.
S4hounddog 06-25-2015 02:04 PM
Check the fuel pressure regulator. Pull the vacuum hose off and check for a gasoline smell, if yes then the diaphragm is shot.
milspam 06-26-2015 09:34 AM
S4hounddog: thanks for the tip, I'll check it out. I was at work when I posted initial post and was in a hurry. The 928 in question is a 1980 Euro M28/11 engine with manual transmission. Engine always starts without any issues, but after driving a bit it does not want to start. I stopped for fuel and could not get it started without removing air cleaner filter and lightly pushing down on sensor plate. Appreciate any additional input on this matter.
JhwShark 06-26-2015 11:12 AM
While, or before, you are sniffing for gas...
check in right rear wheel forward compartment where Accumulator is for gas as well. On the '80 I do not believe you have a return line from Accumulator, and you would observe gas smell from a failed Accumulator.
19psi 06-26-2015 02:48 PM
On my '82, the problem was an inexpensive check valve on the fuel pump. Easy starts when cold but a pain in the ass even during the short amount of time to fill the tank at a gas station.
Danglerb 06-28-2015 07:37 AM
80 Euro is CIS like the US 78/79. After the major failure smelling is done, you need a set of CIS fuel gauges and a shop manual to check pressures.
