harborman's Avatar
Alarm
When I first start my car, the dash shows "Stop lamp" warning. My windows will not operate. Once I press the brake peddle, the "Stop Lamp" warning goes out and everything works. I checked and I do have both stop lights. Does anyone else have this appear upon initial start up?
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 09-11-2015, 05:24 AM
19psi's Avatar
Stop Lamp is supposed to light up after you start and go out after pressing the brake pedal. Owner's manual explains it.
I did have to go out just now and try the power windows while the light is on and they work fine.
There can't be any logical reason to lock out the windows over a brake light issue. It would suck if you really did have a brake light fail and couldn't operate your windows.
Possibly just part of the self test on the '86 model and someone with the same year can test theirs and chime in?
George in Indiana
928 Weissach #153
Cayenne S
Old 09-11-2015, 05:38 AM
harborman's Avatar
I did replace the light check computer as mine did not work when I got the car. I think it was in that little pod behind the foot rest on drivers side floor.
1986 928S
32 valve engine
Old 09-11-2015, 06:07 AM
