Power Windows
Anyone ever work on the power windows? My driver side motor is working, but window not going up or down. Pass window will go down, but needs help to put back up. You can hardly see in there let alone reach in to do anything.
Old 11-12-2015, 06:26 AM
honerboys's Avatar
passenger side ..my guess is the switch - drivers side..is the arm moving at all?
84 928 S - SOLD
2012 Cayenne S
Old 11-12-2015, 08:47 AM
I believe the arm is moving. Have new switches ordered for GP.
Old 11-14-2015, 06:07 AM
garylewa's Avatar
if both the motor and the switch wind up being good take off the interior door panel and check if the roller wheel came out of the slide track....both of my windows did this.
'83 928S - Basalt Black Metallic w/Cocoa Brown leather
Old 11-14-2015, 08:21 AM
Thanks.
Old 11-15-2015, 05:27 AM
harborman's Avatar
Those window switches are all junk and must have been made by the Italians as were the ones in my Pantera. Had had to replace all of mine plus sun roof. Now my rear wiper switch is shot. There was someone selling a solid state switch panel to replace all those console switches. Think it was about $135, but forget where I saw it. It looked like the way to go.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 11-15-2015, 05:45 AM
harborman's Avatar
This is the switch panel I saw.
A "bright" idea: illuminated window switches ** Important order info added ** - Rennlist Discussion Forums
1986 928S
32 valve engine
Old 11-15-2015, 06:04 AM
stepson's Avatar
Those illuminated switches are not available any longer unfortunately. The component prices to build them went out of sight according to Hans at Project 9
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 11-15-2015, 08:19 PM
Well...actually the little wheel on the arm disintegrated! Suppose I'll have to buy a whole regulator just to get the little wheel.
Old 11-20-2015, 05:29 AM
And so it goes...
Other window now going up and down, albeit very slowly. I'll keep exercising it and see if it will free up more. I'll probably just leave the windows down as I only drive "Lucy" on nice sunny days and keep her in the garage. I never leave her alone in a parking lot, so locking is not required.
Old 11-20-2015, 05:38 AM
PCA Certified D.I.
window wheel
I usually machined a new wheel for the window regulator from Delrin, and then bolted it to the arm or machined a new rivet and hammered it. If they stick in the up position, a piece of the wheel has broken off and the flat spot is sliding up and down. Actually it's sliding fore and aft. In the window up position, it goes overcenter and wedges too tightly for the motor to start it back down. (forward in the slide)
Re: the slow moving window. I carefully drill out the "riveted" part of the motor cover and remove the cover, clean the hard grease from the insides, drill and tap the rivet spots for a 3 or 4 mm bolt, then regrease and bolt back together.
1986, '87,'88 928S4, 2006 Cayman S Cabluey, 2006 Cayman S "Burn Notice"
Last edited by Sapientoni; 11-24-2015 at 06:53 PM.. Reason: cover two issues in one reply
Old 11-24-2015, 06:49 PM
garylewa's Avatar
I did basically the same thing he did ^^^^^^^^ to both windows; they both have worked flawlessly since I have owned the car.
Old 11-25-2015, 11:02 AM
Thanks guys. I found new little slider wheels on eBay.
Porsche 928 Window Regulator Plastic Roller Guide Repair Kit 1978 to 1995 New | eBay
I suppose it's tricky to fish that mechanism out of the door. Guess I'm fixin to find out!
Old 11-25-2015, 01:32 PM
Network Native
Danglerb's Avatar
Maybe fix it without removing?
Old 11-25-2015, 03:06 PM
Removed the regulator, which was quite easy. Had to grind the peened over end on the wheel axle, then it popped right out. Installed the new wheel and peened over the end. Installed the regulator getting the little wheel in the groove. A little tricky but was easier than most 928 repairs. Window now goes up and down like new. Been operating the pass side window and it's speeding up. I will later on pull that regulator and grease the gears when I run out of more important repairs.
Old 12-04-2015, 04:40 AM
