Window winder relay - hot, hot, hot
Hey all,
Been sorting through the various issues in this car, while going over the CE panel I noticed that the window winder relay was very hot, too hot to touch bare handed.
Here are my thoughts; heat = excess load or resistance, but it heats up without the window motors even being activated. So excess resistance leaves me with a bad relay? It seems like the heat is mainly in the 30 prong and the large grey resistor above the coil. I'm assuming its probably a bad relay but welcome input. Should I test the draw at the motors before replacing the relay?
1989 - 928 S4
Old 08-05-2014, 11:52 AM
Network Native
Danglerb's Avatar
What do the relay plug contacts look like?
Testing for a short or something sounds smart. If a new relay heats up, pull it until sorted.
Old 08-05-2014, 02:03 PM
Prong 86 had some white fouling and light pitting on it, I sanded and cleaned it but no change. Inside the relay looks pretty clean, but had the smell of baked electrical components.
1989 - 928 S4
Old 08-05-2014, 02:42 PM
was this ever sorted? if so what was the fix?
Old 05-18-2016, 08:26 AM
Petie3rd
Mrmerlin's Avatar
put deoxit 100 into the CE panel connectors the relay has a bad connection thus the hi resistance and heat
Old 05-19-2016, 04:47 AM
