-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   some sense about sensor (http://forums.pelicanparts.com/porsche-928-technical-forum/910550-some-sense-about-sensor.html)
gt2race 04-16-2016 12:08 PM
Hello Gents , can anyone tell me the exact location of the " crank sensor "
I thought that I found it at the top of the bell housing just at the firewall .. nope
this is not the crank sensor and it has a round sorta plug ( a dead end ) thats mounted above the driver side valve cover - it is obviously for some type of testing
I cannot see anything on top of the engine that resembles a standard crank sensor
:eek::eek::rolleyes:
any help is very appreciated
cheers
Lawrence from So Calhttp://forums.pelicanparts.com/uploa...1460833616.jpg
http://forums.pelicanparts.com/uploa...1460833648.jpg
http://forums.pelicanparts.com/uploa...1460833678.jpg
gt2race 04-16-2016 08:37 PM
coming to my senses ... so after all my frustrations
can I assume that there is no crankshaft sensor that is connected to the actual ignition system and in fact ... the crank sensor is a stand alone " reference " pick up and would only be useful to me if I had the correct plug in timing reader meter
am I correct ...
stepson 04-16-2016 09:27 PM
You would have a crank position sensor only if your car was an 1984 Euro or any model 1985 or newer engine.
Since your car does not appear to be a 1984 Euro (or ROW) car, and is definitely not a 1985 US or newer car, your engine will not have a crank position sensor.
If you include the year model of your car in your signature, specific questions about your car would be much easier to answer.
AirtekHVAC 04-17-2016 04:04 AM
Wow, sure looks good under the hood!
JhwShark 04-19-2016 08:01 PM
Sharp, You should get the cover ($12) for the 14 PIN Connector and Jump Post...add your paint scheme to it! What year and color?
