Question About 1985 928S Front Engine Harness
I can't seem to find the oil pressure sender wires in the factory wiring diagram. I must be blind?
Can anyone tell me the color codes and wire gauge of the oil pressure sender wires for a 85' 928S? I'm trying to rebuild my front engine harness that connects near the jump post using the 14 pin connector. Thanks |
Page 3 zone K-25
14 pin Terminal 2 Oil pressure terminal WK blue/black stripe 14 pin Terminal 4 Oil pressure terminal G Blue/white stripe 14 pin Terminal 6 Oil level switch Green/blue stripe |
Thanks Neil! Probably would help if I was looking in the right spot. I was under the engine portion of the wiring diagram.
Does anyone have a good wiring diagram color decoder? |
Never mind I see the color code now. Thanks again for the help!
| All times are GMT -8. The time now is 08:26 PM. |
