Dashing away
looking to remove my 1982 - 928 Porsche " dash board "
![]() mine is trashed along with the rest of the interior so Im looking to make this my autocross and track car and I can make a nice aluminum dash easily any and all tips are appreciated I dont need a a blow by blow description - just a bit of help is fine one question I have is - do I need to remove heater and ac parts from outside the car such as behind the firewall any and all tips are very welcome Im a retired VW and old muscle car owner so Im fairly handy with a wrench ... I dont bend so easy but I can usually get along with a bit of good advise help is good cheers Lawrence from sunny So Cal ![]() ![]() |
Remove the steering wheel and instrument pod.
Remove the console. Watch for the screw from the glove box into the console. The dash is held in by a bolt and screw (or is it 2 bolts)on the far left and the far right underneath + the 3 allen head bolts that support the steering column. That's all.
John Curry (Drift King) 928OC member Grand Prix White 1994 GTS AT (The GTS) Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz) |
Dash
Will be interested in hearing about your progress. I plan on doing mine soon, and would be interested in any tips you may have. Good luck with your project !!!
Dash
Will be very interested in hearing about your progress. I plan on doing my dash very soon also. Best of luck on your project !!!
Network Native
Dash doesn't weigh much, I think its aluminum under the covering.
Im a pretty lucky Dude I guess . the dash came out much easier than I thought
I did find a very specific guide when I used my Google and simply wrote " how to remove a 928 dash " it included pictures along with specific advise it was exactly what you Gents mentioned I did cheat a bit and cut each end almost off using my trusty old Milwauki sawzal it just made life easier to get those 4 bolts off ... Wow , it literally is held on by very few fasteners just want you to know that it took longer to get the console and dash pod out than it took to get the dash out - I really did not need a sawzall at all Im not going to use the old dash since Im planning to make a simple aluminum one I was pretty surprised how easy the whole process was thanks for making life easier Gents I will add more pics of the car as things progress Im very excited which doesent happen so often when yur 66 years young ! I will still keep the dash pod and instruments |
