LinkBack | Thread Tools | Rate Thread |
FS 1983 Porsche 928 - Consistently Maintained- Impeccable Shape-4 owner car-5 Speed
Porsche 928. Surviving, Consistently maintained Porsche. Ready to drive and enjoy. Bilstein suspension, 5 speed and LSD. I have receipts from the last two owners. From the original owner there are partial stamps in the original maintenance booklet. This 928 has been driven and properly maintained throughout its 33 year life. Surprisingly hard to find in a 928! Major refresh/ reseal in 2012. Included was the water pump, seals, porktensioner, new motor mounts, Brake master cylinder, Fuel lines, Tune up, Vac lines, Power steering line, rack bushings, shifter bushings, New side mirror. Over $9000 in receipts since 2012. New window seals, genuine Porsche shifter, Window washer replacement, multiple relays, sunroof seals, replaced all interior lights including the pod, New under floor padding, newer floor mats and rear hatch mat. The interior is in great shape. NO DASH CRACKS. Normal leather wear. The exterior paint is in awesome shape! All original except for a small replay area on the lower drivers side rear quarter panel. Normal road chips. Glass is in great shape! The coolant light stays on. No leaks, just need a new switch. The front brake need replacement. I have the pads and will replace them for the new owner if negotiated. I have receipts. Please ask any question you have. jhp944@gmail.com Sold as is |
so how long have you owned it?
Ed 85 928 5 spd (guards red over tan) 07 Shelby GT500 6 spd (torch red over two tone black and red leather) |
Coolant Reservoir Light -
Hey J - Just a thought but you might check the wires that go to the coolant reservoir sensor. I had a similar warning light "ON" (just one of the many electrical issues) when I purchased "Miss Purdy". After cleaning the crud off the float, both sides of the electrical pins in it's connector and then resoldering the wires that go through the sensor cap at the top of the float itself - the light has been off ever since. Never did really determine what the original problem was. Too much resistance in the circuit somewhere ?
Sounds like you have a very nice car - ![]() Good Luck, Michael
1984 928S - "Miss Purdy" 1987 911SC - "Frau Helga" 1986 930 - "Well Hung" 1975 911 Targa "Blue" |
