928 deck height tolerances
Hi;
85 m28 / 43
Does anyone have the deck tolerances for this block? How much can it be cut?
TJ
Old 08-02-2016, 11:56 AM
Petie3rd
Mrmerlin's Avatar
how much do you need ?
what ever you do make sure to also cut the tops of the pistons the same amount.
they do make a thicker version head gasket standard is 1.1 Mm thick is 1.4 mm
I had .020 in. removed from each deck my heads are already at min cut thickness
Old 08-04-2016, 04:57 PM
