VDO light control module harness
Does anyone have a vdo light control wire harness out there.
I can't find anything online to tell me where the wires go . I pulled the plug apart and the plug broke into pieces. I glued the plug back together But don't know what order the pins go back in. Looking for a color coded wire diagram or just a picture of the wire configuration so I can put the plug back. Thanks everyone |
Do you have the wiring diagram? It clearly shows the lamp control unit and the wire colors for each pin in Part V ( page 12)
I don't have a wiring diagram for it. I only have diagrams that I took off the internet and there's nothing there.
It's a 12 pin connector about 3 red,black wires and white,black wires put not sure where they go. Don't want to fry anything. |
PM me your email address and i'll send you the wiring diagram. Is your car 79 (CIS) or 80 (L-jet) fuel system?
The lamp control wiring is the same, but you should have the complete wiring diagram, you'll need it again :) |
Jluna0595@aol.com
thanks |
Sent diagrams and some other info.
| All times are GMT -8. The time now is 01:09 AM. |
