Don't bet your car on this! Tow eye warning.
When winching the car onto a trailer (approx. 30 degree slope) this let go, sheered straight through, no additional weight on the car, brake off, lucky I was in it steering it .
A friend that knows more about metallurgy than I do (he doesn't need spellcheck to spell it )pointed out that the metal became brittle because it was plated, Porsche should have left it alone and put up with a bit of rust.
Any expert advise?
'82 928,2002 4.3 lexus quad cam VVTI V8,5 spd Auto.(at the front)BorgWarner 3.08/1 LSD-at the back-Weisach retained,Transaxle gone.Borla exhaust,XSchops Cayenne big brakes front ,968 front brakes rear.Mk4Supra m/s & servo. Alloy rad,1380kgs(3036 lbs(53%F/47%R))
Old 09-03-2016, 04:42 PM
Mal81's Avatar
Good thing mine has a coat of rust on it. It's good to hear that neither you or your car were hurt!
1981 928 Euro "Babied and Pampered"
Old 09-03-2016, 06:09 PM
PCA Certified D.I.
are you certain it hadn't been bent and then straightened?
1986, '87,'88 928S4, 2006 Cayman S Cabluey, 2006 Cayman S "Burn Notice"
Old 09-10-2016, 05:09 PM
not while I have owned it.
If these things are that fragile that they break that easy (previous bend or not- how much force would you have to put on it to bend it?) basically if you are not the original owner of the car, and know the complete history, throw it away and set up something that can be trusted. And even if you do know it's complete history, it's crap, throw it. don't rely on it for the purpose it was designed for.
OK it's 34 years old, (but probably would not have got much use in that time span) it's a cheap casting, when will it let go? who knows?
screwed both ways, difficult to get to the tie downs on the rails as the dam is in the way. and nothing else to get a grab on without destroying the dam.
Not a one off either, a guy on rennlist has had the same thing happen.
Old 09-11-2016, 02:54 PM
Pete R's Avatar
I think your friend is wrong. Zinc plating is like .003 thick. It just goes in chemical tanks, there are not temperature extremes to make it brittle. It's merely a corrosion resistant coating. He may want to review some school books. It most likely broke because it was being pulled at an angle
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 09-11-2016, 02:58 PM
non-whiner
mreid's Avatar
It is also cast, not forged, meaning any lateral force like you applied was going to result in the same outcome.
"Too much is just enough."
Old 09-11-2016, 03:10 PM
Regardless , it is a piece of crap. Use at own risk, or, get it X rayed prior to use.(only way you will ever know, and then if it should be pulled at an angle it dislikes--Doom.)
Someone on rennlist pointed out that the later models had a different design/shape.
Could old Ferdys boys have realised the weakness?
Old 09-11-2016, 11:57 PM
Pete R's Avatar
I agree they are horrible. You're lucky you got the end out. My car had the end of the eyelet still broken off flush in the hole from the PO. They make racing hooks for 944s that screw in like that that are really good. I'm not sure if it's the same thread size but if they are I'd look at some of those.
Neon SRT4 track car
Old 09-12-2016, 06:50 AM
So yours is yet another one that has sheared off,
I was probably lucky getting the threaded bit out, there was so much much dirt in there, I had to give it a real good clean to get it screwed in to start with.. I don't know anybody that owns a 944 or I'd check it out. The thread is definitely a one off . need something as it is neer impossible to hook on anywhere else.
I'll ask on the 944 forum and see if someone can post a pic'
Old 09-12-2016, 03:56 PM
Pete R's Avatar
Something like this, Pelican may have them too.
https://www.saferacer.com/products/rennline-porsche-folding-race-tow-hooks?gclid=CLKE5NynjM8CFYsfhgoduNkA4A
Neon SRT4 track car
Old 09-13-2016, 05:11 AM
The swivel loop looks like a better design. (but will the join be a ready made weak point?) Might ask an engineer that machined some splined half shafts for me to see if he can duplicate the thread onto something with strength.
Old 09-14-2016, 03:22 PM
Pete R's Avatar
It's forged steel. I bet you could lift the whole car up with that hook. It's made for pulling cars out of gravel traps and tires barriers, sometimes missing wheels. If you need more than that hook something much more serious has happened
Neon SRT4 track car
Old 09-15-2016, 04:59 AM
Dropped in on engineering shop yesterday, no problem duplicating the thread, will be made in forged steel, spare time job, so will pick it up in a couple of weeks.
Strength will not be an issue, he makes half shafts for drag cars ( Have these in my 928,only cost $300 more than standard street use version, they will still be there, looking new when the car is a heap of ferrous oxide and alloy scrap)
Problem with just buying the one you posted, Australian dollar is worth about two flat rocks, so $100 US becomes about $140. postage will get it past $170, Custom made one will cost about $100 Aust.
Will post a pic when I pick it up.
Old 09-15-2016, 05:13 PM
