Network Native
Danglerb's Avatar
I bought a set of wrenches that are ideal for the bellhousing bolts, double box end flex head ratcheting extended sockets. Its like a regular flex head ratcheting wrench, but the sockets are extended from the face of the wrench about half an inch, they are miracle workers.
Old 02-19-2018, 01:40 PM
stepson's Avatar
Got a link?
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Cobalt Blue 1989 S4 AT (The Blue Car)
Indishrot 1984 Euro S AT (The Stepson)
Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 02-19-2018, 08:03 PM
Network Native
Danglerb's Avatar
Same design showed up in half a dozen brands, mine are I think EZ Red, but this looks the same. https://www.cpooutlets.com/platinum-tools-99650-5-piece-10-metric-xl-ratcheting-wrench-set/pltn99650,default,pd.html
I don't recall if mine are spline or not, but think they are.
US 83 zinc metallic 5 spd, aka the nice car.
Euro 85 black, 5 spd, the fast rough track car maybe car.
Euro 84 red, AT, only car in garage in years, my parts car, soon to go last 5 years.
Old 02-20-2018, 01:09 PM
stepson's Avatar
Thanks for posting that link.
Old 02-20-2018, 07:39 PM
rufrob's Avatar
Sweet.
Never give up
Old 02-21-2018, 03:27 AM
rufrob's Avatar
Just discovered something strange. If I read it correctly the engine in the first car is a 91 engine.
The car is an 89.
Also all the air pump piping is gone. I took all that off my 930, should I bother to swap all that over from the 87 engine? Can I install the manifolds and air pump pipes with the engine in the car?
Never give up
Old 02-22-2018, 03:14 AM
stepson's Avatar
M28/42 would cover 87-88 ROW A/T, 87-88 US A/T, and all 89-91 A/T.
As far as I can see, the only reason they split the 87-88 ROW AT from the 87-88 US was a weight difference. 89-91 weighed the same no matter the destination apparently.
Old 02-22-2018, 10:05 AM
rufrob's Avatar
Thanks I read somewhere that the engine number indicates its a 91. Iíll look for that wed source again. If what you say is true then I could uses the either engines. According to Japanese rules the engine must be of the same series or newer.
Never give up
Old 02-22-2018, 11:08 AM
stepson's Avatar
Sourced information from 928gt.com:
https://www.928gt.com/t-928engine.aspx
Old 02-22-2018, 02:09 PM
rufrob's Avatar
Thanks. Now to decide to swap over the air pump pipes or just block them off.
Never give up
Old 02-22-2018, 09:57 PM
stepson's Avatar
If you don't have to use the air pump and don't have to have it installed for emissions, why not just remove the air pump and all the pipes and hoses?
If you sell the car to someone just send the bits along with the car. The next owner might need to install them for emissions and will therefore have the ability to do so.
Old 02-23-2018, 08:08 AM
rufrob's Avatar
Thatís a good point. I just arrived at that conclusion myself this morning.
I got all but the pipe at the back of the motor off. Iíll use the existing pipes to cap the system. I still have 27 days paid holidays, so Iíll see how many I can use this month. Thankfully the 928Tt looks easier than the 944.
Never give up
Old 02-23-2018, 12:28 PM
rufrob's Avatar
Here is a photo of the vent bolt for the air pump and pipe. I could not find a cap for that pipe. Can I use that 12mm ss bolt to plug the air injection ports on the head?
Never give up
Old 02-25-2018, 04:19 AM
rufrob's Avatar
I found this in some of the ports
So I cut the bolts I bought, applied the washer and installed them. Perfect.
The engine has not exhaust manifold sealing rings. Wow they are expensive and unlike regular gaskets are not reusable.
Last night I removed the front spoiler and installed the ac condenser and radiator to get a sense of accomplishment.
Never give up
Old 02-26-2018, 12:05 PM
rufrob's Avatar
Feels like I reached the turning point. Waiting for the exhaust manifold o rings. I decided to tackle the torque tube. It was much easier than the 944.
I pulled the shaft out by hand. The damper fell out and after lubing the inside and using a block of wood, shop rags and I long pole I got the bearing out. Only 2.
I got a bit too adventurous trying to replace the bearings at home, at night, on hay fever medicine and the inevitable happened,
To be fair I strained my wrist removing the engine but the reduced mobility contributed to the hammer blow to the finger and damage to the new bearing. I ordered 3 so I use the bench vice...
Never give up
Old 03-02-2018, 03:05 PM
rufrob's Avatar
Got a bit too ambitions and tore the bearing bushings. So during the wait the rest of the project anon.
Never give up
Old 03-04-2018, 12:13 PM
rufrob's Avatar
Got a lot done a few days ago. Exhaust manifolds with new orings, air injection port sealed, front suspension cleaned and bolts installed, torquing comes later, ac compressor, ps pump and oil cooler hoses. Found a hole above the oil cooler junctions. Does anyone know what itís for?
Never give up
Old 03-08-2018, 12:08 PM
rufrob's Avatar
Looks like that hole was part of the oil pressure system. However it filled in on this engine. It goes nowhere.
Got the ps done, radiator and transmission cooler lines. However 87 and 89 hoses are different. Which is better? Transmission front seal tc and bearing holder are also done, half shafts rebooted and installed.
Next week engine rear main seal, fuel system, I should have the tt bearing sleeves too.
Never give up
Old 03-15-2018, 11:09 PM
rufrob's Avatar
I got new bearing sleeves but they are quite loose. Should they be?
Never give up
Old 03-22-2018, 04:52 PM
rufrob's Avatar
Blackseard bearing appear to not have a very tight clamp on the shaft given the grooved/pronged inner sleeve. The mechanics here I ask all say it should be loose and will work when necessary if the shaft heats up. Iíll slap it together and see what happens.
Btw, while installing the torque converter with housing I greased the seal and carefully slid the TC in while turning it. I felt the prongs slot in but it cover didnít sit flush with the transmission housing. As I snugged the bolts down it eventually seated flush but not the TC/transmission it wonít turn by hand. Is that normal?
Never give up
Old 03-27-2018, 12:38 AM
