rufrob's Avatar
Just finished doing a clutch on a C5 Corvette. Similar setup as the 928 with the rear mounted transaxle. At least I could do it in a shop with a great set of tools.
I still find the 928 more rewarding and to do. The Vette is just so cheaply made.
928 update. After assembling the torque tube the new sleeve felt tight. Almost as tight as when I first took it apart, guess the lube meant something.
I did the rear main seal today, it popped out so easily and slid back in so easily I think something is wrong. I put a wire brush to the flexplate/flywheel to get rid of the surface rust washed it and sprayed some WD40.
I lower the back end again to remove the TC and see whatís what. I realized I didnít fill
It with atf before installing it. Got a 20l drum of ATF today but I have to work tomorrow so Thursday is the day I put the driveline back together and exhaust system. Next challenge, the fuel system.
Never give up
Old 04-03-2018, 01:31 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #101 (permalink)
rufrob's Avatar
Never give up
Old 04-03-2018, 01:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #102 (permalink)
rufrob's Avatar
Success. I attached the tc to the bell housing an put into the tranny. Thatís a no go. I did it the proper way: install the tc first make sure itís properly seated then put the bell housing on. Now all is well. Next tt, torque down the rear suspension.
Never give up
Old 04-05-2018, 05:22 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #103 (permalink)
rufrob's Avatar
Got most of it back together. Engine rotates but so start.
Does anyone know what this plug is for near the oil pressure switch? On the 87 engine wires come directly out of the main harness here.
Never give up
Old 04-29-2018, 09:21 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #104 (permalink)
rufrob's Avatar
87 sacrificed so others can live.
Anyone need 928 parts?
Never give up
Old 05-02-2018, 01:36 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #105 (permalink)
rufrob's Avatar
I seem stuck. The engine turns and the cps shows proper resistance, new fuel pump works when I manually close the relay. Guess I should wait for the other relay beside the ecus.
Interior lights and digital instruments donít work.
The headlight motor suddenly wonít stop rotating up and eventually hits her ac condenser. It didnít do that before.
Today I cleaned the car and fed the leather.
Gonna try to repair the dash.
Never give up
Old 05-05-2018, 05:52 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #106 (permalink)
rufrob's Avatar
Not a roller anymore.
TT, starter, transmission, exhaust, CE, leather interior, power locks splash guards, fuel pump,tbwp, etc done.
Windows, sunroof, lights, blower motor, wipers work. Now Iím feeding the leather with lexol and Neats Foot oil.
From this
and this
But the digital instrument cluster doesnít work. Engine cranks but the fuel pump relay wonít close. I tested the cps and it tested fine. I ordered a new cps.
Never give up
Old 05-06-2018, 05:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #107 (permalink)
stepson's Avatar
Are you using the computer from an '89 and up or an earlier car? Earlier car computers will start the engine but not support the digital dash electronics.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Cobalt Blue 1989 S4 AT (The Blue Car)
Indishrot 1984 Euro S AT (The Stepson)
Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 05-06-2018, 09:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #108 (permalink)
rufrob's Avatar
Good point. I havenít checked the computer part numbers.
Never give up
Old 05-07-2018, 01:37 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #109 (permalink)
honerboys's Avatar
great job and a nice save - did you ever figure out what the gauge to the right of the clock does
84 928 S
Old 05-07-2018, 08:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #110 (permalink)
rufrob's Avatar
The gauges appeared to be connected to the oem wiring harness. Iíll get some pics later.
Anyone know anything about the 3 plug connector on the engine wiring harness near the oil pressure switch?
Never give up
Old 05-11-2018, 04:05 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #111 (permalink)
honerboys's Avatar
perhaps that plug and the mystery gauge are connected since no one knows what either one does
84 928 S
Old 05-11-2018, 06:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #112 (permalink)
rufrob's Avatar
Replaced a fuse and the dash and interior lights came on
She has 97000kms.
Never give up
Old 05-11-2018, 10:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #113 (permalink)
Go go go!
1967 912 (now w/ 50% few random holes in it)
911 w/ 3.2
1974 914 (3.2L swap underway)
1984 928s (S4 engine and suspension), 1987 928S4
Old 05-12-2018, 05:34 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #114 (permalink)
rufrob's Avatar
Never give up
Old 05-12-2018, 07:31 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #115 (permalink)
rufrob's Avatar
After cranking this error message comes up
I have 1 harness with 3 wires running just behind the dipstick. 1 is live, I have no idea where it connects
I have power at the coil, the fuel pump buzzes when cranking and for a second after. Fuel is in the rail. Donít know what pressure yet. Iím sure the fuel filter is plugged.
Never give up
Old 05-12-2018, 08:21 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #116 (permalink)
rufrob's Avatar
Oohhh the dreaded seized and broken cps. Drill baby drill.
Never give up
Old 05-27-2018, 07:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #117 (permalink)
stepson's Avatar
The error message is showing that your battery is weak or defective. It's showing up after cranking because the voltage to the system drops below a certain threshold while cranking. Replace your battery and that should go away.
Old 05-29-2018, 07:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #118 (permalink)
rufrob's Avatar
Thank you so very much. New job has slowed this project considerably.
Never give up
Old 05-30-2018, 03:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #119 (permalink)
rufrob's Avatar
Finally got around to it again. New cps, got fuel, and spark but injectors arenít opening. No power at the injector however when I reverse the noid light there is ground. From a fully charged battery I only get 1-2 minutes of cranking.
Timing checks out, both ECU relays click. Any further suggestions?
Never give up
Old 06-16-2018, 04:36 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #120 (permalink)
