-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   90 roller (http://forums.pelicanparts.com/porsche-928-technical-forum/947467-90-roller.html)
rufrob 02-26-2017 12:43 AM
90 roller
What are rollers going for nowadays? I found a car with papers, mostly straight body, half an engine, no transmission or torque tube. Many bits and pieces inside.
Linderpat 02-26-2017 07:56 AM
500 tops; more likely it is just scrap. "mostly straight body" really means crooked body. Scrap. Half the engine there really means the other half isn't.
rufrob 02-26-2017 11:31 AM
Mostly straight means some minor dents. No accidents. The heads are gone. There are several complete cars around me with no papers. Hence the plan was to strip them both build one car and dump the unregistered body and useless parts. I did it before with 944s.
Linderpat 02-27-2017 04:20 AM
$500 US is what I would offer. Need to see pictures to assess more. There are many many rollers out there, and people can't give them away.
rufrob 02-27-2017 01:03 PM
Does it matter if it still has brakes, suspension, glass and most of its interior?
Linderpat 02-27-2017 04:34 PM
Could be - since those things can be removed and parted out. It depends on condition of them though. If shot shocks/struts, and ripped stinky interior bits, and glass with lots of sandblast, then it is no good even for parts.
Are you buying or selling? If buying - $500 is the offer, and $1K is the top of the deal, otherwise, keep shopping. If you are selling, $2K is the ask, and $1K is the bottom. These cars are great, but still a long way from being valuable as a simple frame with a VIN like 356s and old 911s (plus, we have no frames anywaySmileWavy).
Linderpat 02-27-2017 04:37 PM
in fact, here's one that does have some valuable parts in it that you could likely get for close to $1500, right here on this board: http://forums.pelicanparts.com/porsche-928-technical-forum/946345-1978-porsche-928-sale.html.
The above car sounds like it has the entire drive train intact. If you are looking for a project, the above car would be a good starting point and candidate for a save. Pasha interior is quite valuable on the early cars.
rufrob 04-11-2017 02:31 PM
3 months later the seller contacted me again. We agreed on $600 plus delivery $100. I'll get it at the end of the month because I need to make room for it. Of course it had to happen when I just started building my deck. Spring/Summer projects begin.
Mrmerlin 04-14-2017 06:58 AM
where is the roller located?
rufrob 04-14-2017 02:39 PM
In Japan.
Mal81 04-15-2017 08:40 AM
Oh, wow. Are you planning on shipping it to another country?
Unless things have changed drastically since I last lived there, it will have to pass annual inspections, and the car will pretty much have to be as-new in every way.
rufrob 04-17-2017 03:26 PM
I plan to do a complete restoration/ swap with a parts car, which is an 87 sport model I drove 15 years ago. Since then the owner died and the papers lost. The roller gives me papers and clean vin. I did the same thing to 944 auto a few years. I found a complete S2 with no papers, swapped everything over.
rufrob 04-27-2017 02:01 PM
Well she is here.
rufrob 04-27-2017 02:03 PM
https://uploads.tapatalk-cdn.com/201...783a3c45bb.jpghttps://uploads.tapatalk-cdn.com/201...3785fc0475.jpghttps://uploads.tapatalk-cdn.com/201...4536982f20.jpghttps://uploads.tapatalk-cdn.com/201...02a3883393.jpghttps://uploads.tapatalk-cdn.com/201...c5372109e3.jpghttps://uploads.tapatalk-cdn.com/201...fde48e26e8.jpg
rufrob 04-27-2017 02:05 PM
No exhaust, transmission, torque tube, headlights, most of the engine ancillaries. On the plus side mostly straight body, sport seats. Next week I'll strip it to see what I have.
rufrob 05-01-2017 07:01 AM
https://uploads.tapatalk-cdn.com/201...0e79c53923.jpghttps://uploads.tapatalk-cdn.com/201...9c021e331e.jpg
https://uploads.tapatalk-cdn.com/201...9180a7a9bf.jpg
Seats came up nicely. Thanks vinegar and Lexol. The PO should be shot and castrated for what he did to this car. Instead of removing switches like a human he cut them from the wiring harness. Oh, the joys of wiring harness repair. I sprayed water on the door card and headliner to straighten them out. I wish I didn't give away those headlights I was sitting on for 10 years.
Linderpat 05-01-2017 08:11 AM
She's a roller alright. Good luck with the project, I will follow.
rufrob 05-04-2017 03:58 AM
I'm guessing it's the abs harness is cut. Please https://uploads.tapatalk-cdn.com/201...4abb00293a.jpg
https://uploads.tapatalk-cdn.com/201...775fa319f1.jpghttps://uploads.tapatalk-cdn.com/201...8e7655812f.jpg
rufrob 05-07-2017 02:04 PM
Got a lot of wiring repairs, the dash board, sunroof and headliner done. Luckily I could find 90% of the interior trim. I started compounding the body. Found 3 rust spots around the rear 1/4 glasses. Probably need to compound it about 3 more times. I'm quite pleased.
rufrob 06-08-2017 02:10 PM
Got a crank pulley, timing belt tensioner rollers and arms, I polished rust off the nose of the crank and oil pump crank. I changed the oil, started to turn the oil pump only then I noticed the oil cooler lines are gone. Oil all over the floor. Ahhh.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
