rufrob's Avatar
90 roller
What are rollers going for nowadays? I found a car with papers, mostly straight body, half an engine, no transmission or torque tube. Many bits and pieces inside.
Never give up
Old 02-25-2017, 11:43 PM
Linderpat's Avatar
500 tops; more likely it is just scrap. "mostly straight body" really means crooked body. Scrap. Half the engine there really means the other half isn't.
Ed
78 928 5 spd "Blumaxx" (Minerva Blue; featured in issue #100 Hemmings Sports & Exotics)
05 997 (Meteor Metallic Gray over terra cotta)
06 Mustang GT (Legend Lime)
Old 02-26-2017, 06:56 AM
rufrob's Avatar
Mostly straight means some minor dents. No accidents. The heads are gone. There are several complete cars around me with no papers. Hence the plan was to strip them both build one car and dump the unregistered body and useless parts. I did it before with 944s.
Never give up
Old 02-26-2017, 10:31 AM
Linderpat's Avatar
$500 US is what I would offer. Need to see pictures to assess more. There are many many rollers out there, and people can't give them away.
Ed
Old 02-27-2017, 03:20 AM
rufrob's Avatar
Does it matter if it still has brakes, suspension, glass and most of its interior?
Never give up
Old 02-27-2017, 12:03 PM
Linderpat's Avatar
Could be - since those things can be removed and parted out. It depends on condition of them though. If shot shocks/struts, and ripped stinky interior bits, and glass with lots of sandblast, then it is no good even for parts.
Are you buying or selling? If buying - $500 is the offer, and $1K is the top of the deal, otherwise, keep shopping. If you are selling, $2K is the ask, and $1K is the bottom. These cars are great, but still a long way from being valuable as a simple frame with a VIN like 356s and old 911s (plus, we have no frames anyway).
Ed
Old 02-27-2017, 03:34 PM
Linderpat's Avatar
in fact, here's one that does have some valuable parts in it that you could likely get for close to $1500, right here on this board: 1978 Porsche 928 For Sale.
The above car sounds like it has the entire drive train intact. If you are looking for a project, the above car would be a good starting point and candidate for a save. Pasha interior is quite valuable on the early cars.
Ed
Old 02-27-2017, 03:37 PM
rufrob's Avatar
3 months later the seller contacted me again. We agreed on $600 plus delivery $100. I'll get it at the end of the month because I need to make room for it. Of course it had to happen when I just started building my deck. Spring/Summer projects begin.
Never give up
Old 04-11-2017, 01:31 PM
Petie3rd
Mrmerlin's Avatar
where is the roller located?
^^^ Stan ^^^ 2011 BMW K1300S Magma red
1988 S4 5 sp, Black / Black leather/ Carmel carpet
Old 04-14-2017, 05:58 AM
rufrob's Avatar
In Japan.
Never give up
Old 04-14-2017, 01:39 PM
Mal81's Avatar
Oh, wow. Are you planning on shipping it to another country?
Unless things have changed drastically since I last lived there, it will have to pass annual inspections, and the car will pretty much have to be as-new in every way.
1981 928 Euro "Babied and Pampered"
Old 04-15-2017, 07:40 AM
rufrob's Avatar
I plan to do a complete restoration/ swap with a parts car, which is an 87 sport model I drove 15 years ago. Since then the owner died and the papers lost. The roller gives me papers and clean vin. I did the same thing to 944 auto a few years. I found a complete S2 with no papers, swapped everything over.
Never give up
Old 04-17-2017, 02:26 PM
rufrob's Avatar
Well she is here.
Never give up
Old 04-27-2017, 01:01 PM
rufrob's Avatar
Never give up
Old 04-27-2017, 01:03 PM
rufrob's Avatar
No exhaust, transmission, torque tube, headlights, most of the engine ancillaries. On the plus side mostly straight body, sport seats. Next week I'll strip it to see what I have.
Never give up
Old 04-27-2017, 01:05 PM
rufrob's Avatar
Seats came up nicely. Thanks vinegar and Lexol. The PO should be shot and castrated for what he did to this car. Instead of removing switches like a human he cut them from the wiring harness. Oh, the joys of wiring harness repair. I sprayed water on the door card and headliner to straighten them out. I wish I didn't give away those headlights I was sitting on for 10 years.
Never give up
Old 05-01-2017, 06:01 AM
Linderpat's Avatar
She's a roller alright. Good luck with the project, I will follow.
Ed
Old 05-01-2017, 07:11 AM
rufrob's Avatar
I'm guessing it's the abs harness is cut. Please
Never give up
Old 05-04-2017, 02:58 AM
rufrob's Avatar
Got a lot of wiring repairs, the dash board, sunroof and headliner done. Luckily I could find 90% of the interior trim. I started compounding the body. Found 3 rust spots around the rear 1/4 glasses. Probably need to compound it about 3 more times. I'm quite pleased.
Never give up
Old 05-07-2017, 01:04 PM
rufrob's Avatar
Got a crank pulley, timing belt tensioner rollers and arms, I polished rust off the nose of the crank and oil pump crank. I changed the oil, started to turn the oil pump only then I noticed the oil cooler lines are gone. Oil all over the floor. Ahhh.
Never give up
Old 06-08-2017, 01:10 PM
