Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 928 Technical Forum
Hi Ron - sorry about the flare, kind of a bummer.
Greg makes super nice hoses, which I am sure you already know. I can just pop on over there at lunch, but of a longer drive for you I know.
1967 912 (now w/ 50% few random holes in it)
911 w/ 3.2 (ugly but kinda fast)
1974 914 (3.2L swap underway)
1984 928s (with S4 engine and suspension)
1987 928S4
Old 09-15-2017, 05:42 PM
Kool
AirtekHVAC's Avatar
Yea, eventually I will get some GB hoses....on a bottom feeder budge tight now. Perhaps you might be able to find out what kind of flare is used for me, that would help. It's on the hard line that meets the rubber line coming from the fuel filter.....
Ron
1978 5sp (#30) project-Wreckscue
1979 5sp Euro basket case
1982 5sp resto project
(Yes, I now have 3 project Sharks)
Old 09-15-2017, 05:53 PM
Hi Ron - I have one of his hoses in the '84. Hardline from under car to front, that one?
1987 928S4
Old 09-15-2017, 06:09 PM
Kool
AirtekHVAC's Avatar
Yup. The hose is fine, I have a brand new one in that spot, the problem is the flare on the hardline. This car sat for quite some time, and I had to cut the old hose nut off with a dremel. I slipped and cut a slit in the hard line flare, now it leaks. I need to cut the flare off and reflare it.
I have a short piece of hard pipe with a good flare on it, cut off a parts car, if I have to I'll cut the flare off and braze the replacement piece on, just a pain to purge out any fuel in the line, but I have done it before.... sigh...
Ron
Old 09-16-2017, 02:09 AM
Kool
AirtekHVAC's Avatar
I'll post a pic later today, I have to run some errands this morning, and then I'll disconnect the hose and take a couple.
Ron
Old 09-16-2017, 02:10 AM
Kool
AirtekHVAC's Avatar
Snagged this pic from eBay, but this is the flare I need to cut out and redo. Type / tool needed?
Ron
Old 09-16-2017, 05:49 AM
Oh, sorry Ron, misunderstood
1987 928S4
Old 09-16-2017, 06:08 AM
Kool
AirtekHVAC's Avatar
Got the flare leak solved...not quite how I wanted, but I cleaned it all up with a dremel wire brush, degreased with carb cleaner, and dried, then used loctite red on the flare face and threads, screwed on the hose, and let it cure. Not the best solution, but the swivel of the hose is at the fuel filter, and allows for filter and accumulator removal. The original one lasted 38 years, so I will readdress if it starts leaking, or hopefully, in another 38 years....
Reassembled, pulled off coil wire, and cranked over to build fuel pressure....leaks all over the dammn place.....I made a joint under the fender well, where the PO cut the end off the accumulator, and used a straight piece of brass to join the 2 rubber ends...I brazed a "ring" on the cut line entering the accumulator and shoved the hose over it, and clamped to prevent it from popping off, but accidentally grabbed the PO's brass fitting instead of the barbed one I had just bought ( too much crack I guess)...leaking like a bear right there...my own fault. I will remove that joint soon and run a new hose from the accumulator to the pump. Anyway, put in the barbed fitting and tightened, leak fixed.
Leaking at the small joint I had to make just before the pump outlet...just had to tighten up the clamps a little...
A sheetload of fuel leaking under the hood.....my just made rubber hose was leaking like a screen door on a submarine...I thought it felt loose on the barbs....turned out that for some reason this Euro has a little bit smaller barbs than on my 78 or 82...I had to switch to 5/16 barricade fuel line...that did the trick...no more big leaks...still have a little fuel seepage on top of the distributor, hope to resolve that this weekend....tried to start her up...rumbled a couple times, then backfired at the sensor plate.....got called up for dinner, so I am ready to try to get her to fire.
Ron
Old 09-20-2017, 06:43 PM
Kool
AirtekHVAC's Avatar
i am a dumbass... I knew one of my headlight lenses was loose, but thought, "hey, it's dark out...let's try the lights...." self, bad idea...
So, does anyone know if the left and right glass lenses are the same? I have a spare passenger light...hope I can use it here...the broken one is from the drivers side.
Ron
Old 09-20-2017, 06:49 PM
Bummer. Looked at PET quickly but it looks like there is only one part number, so I think the spare should work.
1987 928S4
Old 09-20-2017, 07:03 PM
Kool
AirtekHVAC's Avatar
Thanks for looking skip, I was too upset to look it up last night.
Ron
Old 09-21-2017, 05:13 AM
I'd try a test fitting, don't take my word for it. Fingers crossed.
1987 928S4
Old 09-21-2017, 06:21 AM
stepson's Avatar
Exact same
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Cobalt Blue 1989 S4 AT (The Blue Car)
Indishrot 1984 Euro S AT (The Stepson)
Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 09-21-2017, 09:15 AM
Kool
AirtekHVAC's Avatar
Yay!!!
Ron
Old 09-21-2017, 06:14 PM
Kool
AirtekHVAC's Avatar
Big results today !!!
https://youtu.be/ecv-1-3Dh1A
Ron
Old 09-24-2017, 05:36 PM
Congratulations Ron, nice moment and neat that it was a family affair.
Well done.
1987 928S4
Old 09-24-2017, 07:09 PM
stepson's Avatar
Congratulations Ron!
I don't know why Oak Green was such a problem for Porsche, but everyone I personally have seen has been oxidized worse than any red I have seen.
BTW, don't get rid of that broken light. Roger sells a replacement lens: pricey but cheaper than a complete light. At some point, the complete lights might be NLA and everyone will be looking for lights to put lens on.
Old 09-26-2017, 12:36 PM
very cool - getting the engine to run always a big step in restoring a car - good job
84 928 S
Old 09-26-2017, 01:25 PM
Kool
AirtekHVAC's Avatar
Thanks for the positive thoughts, and the tip on the light John. Iíll save it.
All I could get was a low rpm idle out of her, any throttle and she would cut off.
I removed the injector lines at each injector (already removed at the distributor, found someone removed all but 2 of the little screens) pushed a small plastic tube into each one, filled each with injector cleaner, and then blew through with nitrogen. Gave me a little better idle, but still no throttle. So while it idled, I found that spraying injector cleaner around the foot of each spider increased the rpm. Checking the bolts, they were all loose. Dangit. Time to regasket. I pulled the spider, and legs.
Today I will clean the valley area, replace all the vacuum lines, remove the injectors and make sure they all have good flow, then replace the spider with a painted up spare I already have. Then wait for my new injector bushings to come in, that I ordered last night. Fun.
Ron
Old 09-30-2017, 04:47 AM
Kool
AirtekHVAC's Avatar
Removed the injectors. Rounded 4 of the tension collars. Got the old injectors out of a box from #30, which all still had the collars on them. Soaked all 16 in a bucket of carb cleaner. Was able to drive the rings and rubber bushings off 12 of them with a socket and plastic end hammer and a block of wood. Dremeled the tension rings on the 4 remaining, and drove those off. Blew dry nitrogen through each injector and had 3 of them that would not blow. Put them all back to soak for tonight. I now have 16 working fuel injectors, 8 will go back into the car, 8 will be put in a container of marvel mystery oil to stay soaking until needed.
Ron
Old 10-01-2017, 06:54 PM
