reversing lights
1986 porsche 928 s2
reversing lights dont come on when put in reverse (Auto gearbox) fuse ok relay ok. if i bypass relay they come on but stay on. |
Did you check the back up light switch on the transmission?
dont seem to get a live going to auto box,when i bypass relay reverse lights come on
ive got no power to any of the wires in that are spare tyre well.changed relay made no differents.
Pin 85 is ground Pin 86 Goes to Starter lock out/ back up SW Pin 87 to back up lamp SW then to back up lights Pin 30 to Fuse I hope this is correct, evidently two switches involved. |
hi
if i join pin 30 to pin87 with a bit of wire lights come on, were does pin 86 go .does it go to rear spare wheel well,because i have no live on any wires there,so there for no live to switch on auto box i assume.Thanks for your help. |
https://rennlist.com/forums/928-forum/963712-auto-trans-lockout-switch-differences.html |
hi again
if pin 86 goes to switch on gearbox would i not have a live on one of the wires in spare wheel well,otherwise where does switch get its live from.thanks |
when relay is in is pin 86 live to box,because mine is not
hi
where does switch on box gets its power from to go back to relay.should i not have live in rear well going to switch on box,because all wires are not live there .I thought you should have live going to switch and from switch back to relay live if switch works ok course |
Lets see if this helps and my drawings match your car.
Looks like a 9 pin connector goes to the starter/lock out switch. 5 of the pins go to your gear indicators P,N,D,3,2 2 pins are switched for backup lights. (switches power to pin 86 of the relay coil) Looks like one wire is grey/yellow going to pin 86 or the backup light relay The other lead is yellow/red which might be the hot lead to this switch & Gear indicators. 2 pins are for another switch. (lock out for starter) So do your gear indicator lights work as this look like the same power lead going to the switch for the back up relay. |
No hot wires on switch on gearbox.indicator lights all work apart from P and R i assume bulb blown.Cant work out why no hot wire to switch on gearbox
Do you know which pins are 5 and 6
HI
I think switch is the problem.Any ideas on change it.i know it just an bolts but more worryed about setting it up in right place.Thanks for all your helP last few days. (YOU ARE A TOP GUY) |
| All times are GMT -8. The time now is 11:49 AM. |
