LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
Getting close
Tom, SoCal
1967 912 (now w/ 50% few random holes in it)
911 w/ 3.2
1974 914 (3.2L swap underway)
1984 928s (S4 engine and suspension), 1987 928S4
Old 11-16-2017, 05:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #181 (permalink)
Blagave's Avatar
Originally Posted by tdskip View Post
Getting close
Not quite......I hope to get the car out to paint by the end of the year, I still have a lot of conversions to do ( electrical, ac, power steering etc.) I purchase a super charger, so that is going to to take some work on how to plumb the air intake and inter cooler. Once back from paint, ther is all the details of assembly. I am behind on my schedule, but that is ok, not going to rush at this point.
Old 11-16-2017, 05:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #182 (permalink)
Ah, well I was thinking it was the mechanical work to get her fired as-is rather than adding a supercharger etc.
Press on
Tom, SoCal
911 w/ 3.2
Old 11-16-2017, 07:22 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #183 (permalink)
Blagave's Avatar
Started working on power steering lines. I am using modified stock lines. I utilized the banjo flanges to the steering box and cut the steel tubing just above the mount on the fender wall. I welded the AN-6 fitting on and used the hight pressure fittings and hose. I was able to make the pressure line and installed to power steering pump after installing a extended AN fitting. I am not happy with the way the return line runs to the plastic tank, so I am either going to make new tank or see if there are other options mounting to plastic tank.
Old 11-20-2017, 04:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #184 (permalink)
Blagave's Avatar
Got a good deal on new seats out of a 993. I did the math and was less expensive to buy these seats instead of redoing my original seats. The seats are the same size as 928 and look like they will bolt right in.
Old 11-20-2017, 04:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #185 (permalink)
Blagave's Avatar
Finished the coolant tank after a few more mods. Plumbed the heater hoses and made a new radiator line from motor to radiator. I used some aluminum billet clamps that add a nice touch and clamp very well.
Old 11-20-2017, 04:58 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #186 (permalink)
Blagave's Avatar
Decided to ditch the 5 gallon windshield washer tank. I purchased a AC Delco pump and built a new aluminum tank.
Old 11-23-2017, 07:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #187 (permalink)
Kool
AirtekHVAC's Avatar
Wow......just.....wow.....
Ron
1978 5sp (#30) project-Wreckscue
1979 5sp Euro basket case
1982 5sp resto project
(Yes, I now have 3 project Sharks)
Old 11-24-2017, 04:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #188 (permalink)
honerboys's Avatar
yo man - in one of those pictures you got your feet on the wrong legs - too much blue agave? - great thread - i like it when people build their own parts and you have mad skills
84 928 S
Old 11-24-2017, 08:11 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #189 (permalink)
Blagave's Avatar
Tackled the power steering resivor. I didn’t like the slip hose fitting and the angle so made aluminum with AN fitting on return line.
Old 11-24-2017, 04:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #190 (permalink)
JK McDonald's Avatar
Hood Clearance -
Hey Blagave - Have you verified your hood clearance once the dust settles and everything is mounted in their final resting place? The alternator, power steering reservoir, etc sure do look like they may be a bit high and wide between the fenders.
Years ago I'd helped a good friend shoehorn a Ford V8 into a Austin-Healey 3000 Mark III. At the last minute we discovered that the hood wouldn't close so it ran with no air cleaner for a while. Ha - On the straight-a-way it was a beast but man that thing turned plumb spooky on a curve. Lots of go and not near enough whoa. God must watch over youthful enthusiasm cause looking back, we were sure lucky to have lived through such stupidity.
Great Project - Michael
1984 928S - "Miss Purdy"
1987 911SC - "Frau Helga"
1986 930 - "Well Hung"
Old 11-25-2017, 04:04 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #191 (permalink)
Blagave's Avatar
Yes, everything clears with room to spare so far. If you look closely, the alt. Is below the strut support.
I have a super charger coming and it should clear, but worried about the intake duct.
Old 11-25-2017, 04:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #192 (permalink)
Blagave's Avatar
Started the layout for rear seat delete. I am building a one piece aluminum frame and will have two hinged access lids. Everything will be covered with the same black carpet as the cargo area. I like what Tony (JP) did with the cargo storage boxes he used, but decided to make my own and pick up some extra space. I got everything cut out, but my brake is on 48”, so need to go to friends shop to bend on bigger brake.
Old 11-26-2017, 06:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #193 (permalink)
I really appreciate all the detailed pics of your project - great work and your rate of progress is impressive. Looking forward to seeing more.
Cheers!
Earlysport
_____________________________________
69 911E, 69 911E RS Rep 3.0L Hotrod, 77 930
IROC REP 3.6L SOLD, 968CS SOLD, 987 Boxster S SOLD
Old 11-27-2017, 11:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #194 (permalink)
Mal81's Avatar
I love this thread! You move so quickly, I'm too late to say this, but if your Power Steering reservoir doesn't work out, know that the early models had a steel reservoir. It looks pretty cool too - Very post-war Germanesque.
1981 928 Euro "Babied and Pampered"
Old 11-27-2017, 12:42 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #195 (permalink)
Blagave's Avatar
Thanks EarlySport and Mal81 for the kind words.
Already finished power steering resivor, so checked off the list for now.
I try to show lots of pictures because you never know if something will help the next guy or sometimes you guys point out something I have missed.
Old 11-27-2017, 03:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #196 (permalink)
Blagave's Avatar
Got the aluminum bent for the rear seat delete. Started making up steel frame for it to mount too.
Old 11-27-2017, 03:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #197 (permalink)
Good Hearted Woman -
Hey Blagave - Have you decided what to do with that lower storage area after deleting the rear seats ? Down the road as a finishing touch to your build - you'll have plenty of room to retro fit one of those Tarantula MonoBlock Amplifiers and at least four 15" combination speaker set ups. That way you'll be musically competitive when playing "Willie and Waylon's - Good Hearted Woman" while waiting at those Sureņo California intersections. If your New Pro Touring 928 doesn't make you a stand out amongst the crowds - cranking that album out at 150 db definitely will.....
Old 11-27-2017, 05:33 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #198 (permalink)
Blagave's Avatar
I will upgrade the stereo somewhat and use part of the seat delete for amps , base etc. Not going to install one of those systems that vibrate the cars next to you....something nice and simple.
Old 11-28-2017, 05:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #199 (permalink)
Adjust The Volume -
Hey Blagave - I was just joking about installing one of those rediculous nose bleed stereo systems that can raddle the street lights. I also keep the stereo volume adjusted to best preserve my hearing for as long as possible. Plus my CW Era Music selections are typically only enjoyed now-a-days by a limited audience.
The storage area left by your rear seat removal would be a good place to carry all your spare cash around.
Michael
Old 11-28-2017, 11:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #200 (permalink)
