Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 928 Technical Forum
Certified Porsche addict
The Glademister's Avatar
Originally Posted by honerboys View Post
you have to "pop" the mirror glass out first - i use a putty knife for this - then there are screws to remove the motor assembly - then i think you pull the wires through tighten it up and re-assemble - there is a tool to remove the pins from the connectors in both the mirror itself and the one under the dash - i think most people just cut and reconnect as you did - i know that's how i did it
Popping the mirror our seems fraught with disaster. It would be my luck I'd shatter that for sure.
Tennessee Region SCCA & PCA
Current projects - '85 928S, '87 924S, '82 931, '14 Cayman
Past projects - '72 Opel GT, '75 280Z, '90 300ZX, '87 944S, '87 944 Turbo, '88 924S (x2), '02 Boxster, '07 Cayman S, '73 914
Old 12-19-2017, 07:52 AM
  Pelican Parts Technical Article Directory    Reply With Quote #41 (permalink)
stepson's Avatar
Your mirrors should be held in with a movable cam that is accessible through the small hole in the bottom of the mirror. If you can look through the hole, you will see several notches. These notches are used to move the cam and release the mirror. I use a slender screwdriver to access and move the cam
This is what the cam looks like once the mirror is out. You can see the 4 notches across the bottom. Since the cams aren't moved much, sometimes they will need to be persuaded to move and release the mirror.
Good luck
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Cobalt Blue 1989 S4 AT (The Blue Car)
Indishrot 1984 Euro S AT (The Stepson)
Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 12-19-2017, 09:44 AM
  Pelican Parts Technical Article Directory    Reply With Quote #42 (permalink)
Good luck
Excellent information! Thank you!
Old 12-19-2017, 10:03 AM
  Pelican Parts Technical Article Directory    Reply With Quote #43 (permalink)
new one on me - i've never seen that before - all the porsche mirrors i've ever worked on had clips like door panel clips holding the glass in - yours certainly look easier to deal with - and yes glademister "popping" the mirror out can be a shattering experience - like the cams above those clips can become stuck after years and need "persuasion" to release
84 928 S
Old 12-19-2017, 11:47 AM
  Pelican Parts Technical Article Directory    Reply With Quote #44 (permalink)
Chin spoiler
Installed a nice used chin spoiler I purchased from a forum member. Next cosmetic fix will be the grill.
Old 12-20-2017, 03:47 AM
  Pelican Parts Technical Article Directory    Reply With Quote #45 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
