stepson's Avatar
Originally Posted by Linderpat View Post
I think your problem lies wholly with the gauge. These are known issues. Have you ever done a pod cluster refresh? Very easy to do, and cures most of these gremlins. At this point, you have eliminated any potential mechanical problem. Your issue is undoubtedly related to the gauge or the ground at the pod. I'm thinking the guage triggers the central warning light to light up.
Damn. Why didn't I think of this? Great job Ed!
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Cobalt Blue 1989 S4 AT (The Blue Car)
Indishrot 1984 Euro S AT (The Stepson)
Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 03-12-2018, 12:05 PM
yep...i even added an extra half a quart over the dipstick level, and still the problem persisted
Old 03-12-2018, 06:55 PM
Ed thanks for tips on this. i will definitely take the pod cluster refresh challenge! thanks for clarifying the "S" designation. its definitely a 1982. i have little documentation on the car unfortunately.
Old 03-12-2018, 06:57 PM
Pete R's Avatar
FWIW, the central warning systems are getting old and they suck. Mine is unplugged. It was lighting the main warning light with out lighting the indicator lights to tell me what is was. I would suspect that system is faulty. As long as you don't lose oil pressure it's fine.
The other thing I thought was that when you accelerate the oil sloshes to the back of the pan away from the sensor. You could install an oil pan baffle. That would fix it if that's what's happening.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 03-13-2018, 05:15 AM
I thought I'd update this thread, which has now been resolved, in case someone in the future has the same issue, with the oil level light. I embarked on the journey of removing the oil pan, since my gasket was leaking anyway, and I really wanted to see what was in the oil sump. fortunately, it was clean, the screen was not clogged, no debris and the baffles were in place. I replaced the pan gasket and motor mounts while I was at it. Still, the engine oil level light came on during acceleration. However, it wasnt long before I realized my alternator was not charging regularly. Attempted to change the voltage regulator, but apparently I have the original Paris Rhone and was unable to get a voltage regulator for it. Long story short, I replace the alternator with a new one courtesy of 928 Specialists, and lo and behold my oil level light no longer turns on! In retrospect, the oil level light should only be lighting when the engine is not running (or charging), so I suspect the lack of charge but have left the oil level light sensor active. Lesson learned: oil level light coming on during hard acceleration is a default to signal that the alternator is bad!
Old 08-28-2018, 12:39 PM
JK McDonald's Avatar
Oil Level Switch -
Hey Jim - Glad you have sorted out your oil level warning issue. Many owners have had an assortment of electrical problems. I found my oil level warning problem to be in the connector plug of the Master Warning Unit (behind the side panel - driver's left foot).
Prior to starting the car - the oil level monitoring switch is the 1st line of defense against damaging the motor from a lack of oil. When the key is initially turned to the "ON" position - the "Master Warning Monitoring Unit" checks the status of the oil level while the oil is static. If the level of oil is LOW the master warning light (!) now turns on. Once the motor is started and the alternator voltage comes up - the "Central Warning Monitoring Unit" is told to ignore the oil level switch. This is because the slosh of oil in a moving car can no longer be monitored accurately.
Good Luck - Michael
1984 928S - "Miss Purdy"
1987 911SC - "Frau Helga"
1986 930 - "Well Hung"
1975 911 Targa "Blue Who"
2006 Audi A6 Quattro "Howdy Audi"
Old 08-28-2018, 07:25 PM
