5 speed transmission "kit" 16V
OK, here’s the deal. I have about 95% of a complete swap out to convert an automatic 928 to a manual 5 speed. I was planning to install this on my ’84 but times change and so do interests. $550 for it all.
The entire set up is out of an ’81. The condition of the transmission is unknown. It prior owner claimed it worked very well, but he lied about too many things on the car for that to be a completely believable claim from him. The car had a failed engine when I bought it so I never drove the car. That said, when I drained the transmission the magnetic plugs had no debris on them at all, suggesting it may have been shifting well. Pig in a poke. There were a lot of newer parts on this car suggesting someone wanted it working well. The odometer showed 68,000 miles if that really means much given the reliability of 928 odometers that we know and love.
Included;
• Complete torque tube with driveshaft, bearings, shifter assembly etc. Bearings thought to be original.
• Bellhousing
• flywheel
• Clutch disks and pressure plate in decent condition, no hot spots on the pressure plates or flywheel that see, a fair amount of remaining clutch surface, 10mm thickness?
• Throwout bearing and assembly, looks ok (?)
• 5-speed transmission, non LSD
• Rear cross member
• Older master and a newer slave cylinder
• Firewall mounting sheet metal parts for the clutch master cylinder, necessary on some cars, some are already set up for a manual installation
• Clutch and brake pedal assembly
• Misc hardware (this is where the 95% comes into play) I most likely have all of it but sorting it out from other 928 pieces and parts may be difficult.
So, if you have a 16v auto and want to go for a manual on the cheap here is the opportunity to do so. I don’t really want to ship this, but I can deliver it in the Houston/Dallas/Austin general area if that helps, for gas money. My phone number is 936-827-3337
1956 Intermeccanica 356 Speedster (sold),1957 Intermeccanica 356 Speedster (sold),,1985.5 Porsche 944 (sold),1955 Thunder Ranch 550 Spyder (sold), 1955 Outlaw 356 Speedster (currently in build out), 1984 Porsche 928S (White), 1984 Porsche 928S (Red)
Old 10-28-2017, 11:53 AM
stepson's Avatar
That's a smoking deal for someone. GLWS
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Cobalt Blue 1989 S4 AT (The Blue Car)
Indishrot 1984 Euro S AT (The Stepson)
Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 10-28-2017, 12:27 PM
honerboys's Avatar
this is indeed a great deal - i did this swap and it looks like everything is here to do it - i put a 79 transaxle in my 84 and the rear carrier did not need to be swapped - don't know if the 81 is much different - tmpusfugit the only other thing i can think of is the exhaust hanger that attaches to the torque tube right in front of the tranny - the autos have a hanger that bolts to the front of the larger auto tranny - the sheet metal firewall pieces are key and since they are included in this you should be good to go - there was a guy on here back in the summer who wanted to do this swap to an 85 - might want to contact him and see if he's interested
84 928 S
Old 10-28-2017, 02:31 PM
honerboys's Avatar
never mind - looking closer at your pictures i see that hanger is already there
84 928 S
Old 10-28-2017, 02:39 PM
Firewall sheet metal
Old 10-30-2017, 05:17 AM
No interest in 30 days. Off to the salvage yard I guess
Old 12-01-2017, 05:48 AM
stepson's Avatar
Maybe post on RL? Lot more folk over there that might be interested.
Old 12-01-2017, 08:49 AM
Is this kit still available??
Old 12-03-2017, 02:32 PM
