harborman's Avatar
86 928 Pod lights
I am going to need some odometer repair as the gear broke recently. While having the Pod out I would like to put in LED bulbs in the instrument cluster. Any recommendations?
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 11-17-2017, 05:38 AM
Petie3rd
Mrmerlin's Avatar
get a can of deoxit 100 and put it on the contacts of the bulbs and poteniometer the original bulbs will glow bright
Old 11-17-2017, 07:55 AM
harborman's Avatar
Yes I will clean all contacts when I pull it out, but was also thinking of replacing all the bulbs while at it. I was just wondering if going to LED's was worth it. I see some for about $1 each.
https://www.superbrightleds.com/moreinfo/led-vehicle-replacement-bulbs/74-led-bulb-1-smd-led-miniature-wedge-retrofit-rvb/2478/1062/?utm_source=googlebase&utm_medium=base&utm_content=74-xHP-RVB&utm_campaign=GoogleBaseChild&gclid=EAIaIQobChMI8P6i49rF1wIVREMMCh0QhggJEAEYASAB EgL8D_D_BwE
1986 928S
32 valve engine
Old 11-17-2017, 08:02 AM
stepson's Avatar
Just remember this: LEDs are polarity specific. You will need to determine the polarity of each LED prior to installing it. In addition, you will need to determine the polarity of each light socket that you are installing the LED into. Any false steps and the LED will not function correctly.
That being said, I installed LEDs into the Stepson and for the most part, I love the results.
But it was a PITA
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 11-17-2017, 08:31 AM
harborman's Avatar
But it was a PITA
Thanks. Yes, LED's are diodes and polarity specific. What LED's did you use and from where?? I only want to do ones in the Pod, nothing else because they may not work in tail lights, stop lights and may screw up the warning computer.
1986 928S
32 valve engine
Old 11-17-2017, 09:39 AM
stepson's Avatar
Yes, that was my thought also. I corrected the illumination by using the Jaeger wedges that have the LED correctly focused and buried into the plastic already.
The warning lights were from Superbright (B85D I believe). I found that my turn signals did not want to work correctly with an LED so I left that as stock. In addition, the alternator warning light is, I believe, what triggers the alternator, so I left that stock. All the others were replaced with a red/green/or blue LED as required.
Old 11-17-2017, 03:25 PM
Petie3rd
Mrmerlin's Avatar
the LED lamps are not dimmable and you will need to remove the dimmer from the circuit for them to work ,
also more important if you do much night driving i find the LED lights are too bright for effective night time vision to occur.
YMMV
Old 11-17-2017, 05:16 PM
harborman's Avatar
YMMV
Yes, LED's have a threshold point for turn on. I may just replace all the bulbs with stock replacements, but I will look into it a bit more. My odometer gear broke so the main reason I need to pull it.
1986 928S
32 valve engine
Old 11-18-2017, 07:30 AM
how hard was it to replace the odometer gear > any tricks perhaps
Old 12-12-2017, 07:51 PM
harborman's Avatar
I have not tackled the job yet but there are some videos on it. Someone on Ebay will do it for about $100 or so. It looks a little delicate. It's going to be a winter project.
1986 928S
32 valve engine
Old 12-13-2017, 05:23 AM
9two8's Avatar
I used this guide when I did my odo-wheel a while back..,
1984 ODOMETER REPAIR PROCEDURE
Old 12-13-2017, 02:33 PM
When you put the odo back together, you might want to add a thin washer to the end of the number stack if necessary to take up any excessive slack. The odo is notorious for skipping numbers because of excess space between the digits. I found I could force it to skip while turning it by hand. Seems to be a design flaw.
Old 12-14-2017, 11:04 PM
Mal81's Avatar
Ditto on the washer - it should be in those instructions posted. Without it, your odometer may not work after a bit.
The job isn't really difficult. It just requires a bit of courage.
Somebody probably said this already: Be very careful removing the needle! The best method I've found is to hold it by the middle (NOT the needle) and ::gently:: wind it backwards. It will loosen and let you take it off.
1981 928 Euro "Babied and Pampered"
Old 12-15-2017, 02:29 PM
