Stalling '86.5 - Quick help
Just bought first 86.5 928S, one owner, 41k. Just delivered yesterday. Ran fine, took it this morning to get gas (on reserve) before I started to start the sorting process. Ran fine until after I filled her up. She starts fine, idles smooth but when you give it gas she stalls.
I had hoped to keep her running while I started to sort out the electrical gremlins but oh well. What should I be checking first ? Thanks and here we go. |
I wonder how long this car has sat? Any maintenance history? Have all the filters been changed? Sounds like it is starving for air or gas or both.
^^^^+1 - could be gas in tank has been in there a while - some sediment in bottom of tank - you stirred it all up when you added gas and now it's clogging something - screen, filter, pump, injectors? - might pull end cap off fuel rail and check flow and pressure - carefully
The car has been driven but not driven much in the last 6 months or so. It needs to be fully sorted which I planned on but mechanically the car seemed like a DD.
I'm inclined to think it's stirred up crap from the tank - eve n the way home from the station she ran fine. Onl started when I went to take her out again. Before I check fuel rail should I replace filter ? |
Check Temp II and MAF
after sitting, she started right up and drove fine again.
Should I be thinking tank cleaning or just change the filter ? |
| All times are GMT -8. The time now is 10:02 PM. |
