-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Question on flywheel differences (http://forums.pelicanparts.com/porsche-928-technical-forum/983239-question-flywheel-differences.html)
Johnny B 01-07-2018 04:35 AM
Hello all,
I have a question regarding the difference in 2 flywheels and don't have both parts in front of me so can't compare the two.
Can a 1986 4.7S flywheel PET part no 928 102 075 01 for an M28.44 engine be used in a later 928 S4 5.0L M28.50 motor with the PET part no 928 102 075 04
I know the part no's are slightly different and obviously so are the engine sizes, however do the flywheels measure & weigh the same and have the same no of teeth?
Any and all help greatly appreciated
Mrmerlin 01-07-2018 12:59 PM
the 86 early flywheel is for a dual disc,
the S4 is single disc.
928 INTL lists two different parts so I would say they are not interchangeable
Johnny B 01-07-2018 08:17 PM
Thanks appreciate the feedback
Sapientoni 02-04-2018 04:27 PM
The number of teeth on the ignition ring are different and will not allow the newer engine/chassis to run at all, for certain if it's an automatic. The later flywheel will not fit the earlier block with the starter mounts being different and no clearance. Maybe a spacer on the crank will allow it to fit, haven't tried that yet, but need to.
Johnny B 02-04-2018 08:28 PM
Thanks really appreciate the information
