928 S4 Painting intake and valve cover question.
Hello - I've been looking for the thread I had found a year or two ago where a member who painted their intake and valve covers made a list of all the gaskets that should be replaced during the process. I would like to purchase all the parts ahead of time so they are at my disposal when I decide to take on the project. I have come up with what I think I will need from Pelican. If someone could chime in and tell me if I got it all that would be appreciated.
Thanks in advance,
Bob
1987 928S4
4 O-rings for valve covers
26 Rubber grommets for valve cover bolts
8 Spark plug bolt seals
2 Valve cover gaskets
10 Thrust ring seals
2 Intake manifold gaskets- distributor to throttle valve
2 Intake manifold gaskets- distributor to cylinder head
I’m Porsche-less! 2010 AMG E63 - what an engine! BMW K1200R - Hang on! 1987 Porsche 928 S4 - SOLD. 1981 Porsche 928 Saved & SOLD. 1976 Porsche 911 S (V8 Race Car) - SOLD.
Yes I'm blue collar, all my white ones got dirty!
Old 03-17-2018, 04:40 PM
Network Native
Danglerb's Avatar
Google fu, put two or three of the known parts in a google search to find the post.
Old 04-05-2018, 08:39 AM
I believe they have a kit that contains all the cam cover gaskets and sealsnPart #:*928-104-447-09-98-INT If you have never changed them you will also want to look at replacing the oil galley pucks with the aluminum pins. I would also replace the rubber hoses under the intake as they are probably hard. You will also need the throttle body gaskets. There are several WYIT things to think about such as knock sensors, TPS sensor, idle stabilizer valve, CPS sensor. Good luck!
Old 04-14-2018, 06:08 PM
Found it, an excellent write up. Half way there on mine.
Executive Summary:
Old 04-30-2018, 07:52 PM
Petie3rd
Mrmerlin's Avatar
call Roger at 928srus he has the list you need and the parts for less
Old 05-01-2018, 07:22 PM
