Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 928 Technical Forum
DIYDanCars's Avatar
Big Reds on a Porsche 928 S4
Is it possible to mount 993 "big red" calipers on a 87 Porsche 928S4? I thought I had read somewhere that big reds would work as long as a 928 GTS brake disc is used. Can anyone confirm?
Current Project: 85' 928S aka Big Red
https://www.youtube.com/watch?v=6-Aj9XRF3fU&list=PL9xcuilqRL70zUvGxxUE3HRLZIA6dFhbr
Old 02-15-2018, 03:42 PM
Petie3rd
Mrmerlin's Avatar
yes they fit I have them on my 88S4 I am using the 993 rotors.
^^^ Stan ^^^ 2011 BMW K1300S Magma red
1988 S4 5 sp, Black / Black leather/ Carmel carpet
Old 02-15-2018, 06:34 PM
DIYDanCars's Avatar
Beautiful car! All I need are 993 turbo brake discs to make big reds work with my 928S4?
Old 02-16-2018, 03:18 AM
Cobalt's Avatar
993TT front rotors? The 928GTS uses the 94 turbo 3.6 front rotors without the cast holes. Essentially the same but the hats of the 993TT are 5mm shorter than the 94 turbo. Same brakes on all three cars other than rotors.
Did you need to adapt for the difference?
I have seen your car up close the color is stunning and unique.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, '93 964 C2, '93 928 GTS 5 speed, '94 Turbo 3.6, M '15 Boxster GTS18 Macan GTS
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS many others
Old 02-16-2018, 03:43 AM
DIYDanCars's Avatar
Does anyone know what is needed to make big reds work on S4's? I'm pretty sure I can't use a standard S4 rotor with this setup. Any help would be appreciated.
Old 02-17-2018, 11:32 AM
