Ignition coil question
I pulled a spark plug and saw no visible spark. I then pulled the coil wire off and saw no visible spark. I put my tester inside the coil wire and there seemed to be a hint of something. My question is, with a new coil, should there be lots of visible spark from the coil wire in order to gauge that the coil is still good?
Also, where does the green wire connect to the distributor? Thanks again for everyone's help.
1980 928S Euro 1983 928S 1988 928 S4 1989 944NA |
Petie3rd
OK please give the year of the car your working on and list all of the things you have fixed
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
The car is a 1980 928S Euro - it has a new fuel pump and relay. I checked the coil wire and it doesn't seem like much spark. The problem is I'm not sure just how much one should see of spark from a fully functioning ignition coil.
Petie3rd
are there 2 white looking things bolted to the the fenderwell with wires on them?? if so one of the these resistors may be failing
SharkHead
Jon
'79 928, 85k Opal Metallic '99 BMW 540i, 97k Titanium '72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga |
Check your input to the coil for voltage with a multimeter. Not sure what reading you should get, WSM will tell you. If volts are good, replace your coil.
1982 Porsche 928, Auto, 4.5 http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945 |
I still cannot find the green wire in my engine compartment. Would anyone have a picture of that location?
Also, who is WSM? Thanks everyone for your help ![]()
With a 30 yo car, it may not be green anymore. It may look more white with a yellowish/cream colored tint. You will probably need to find the end at the distributor and work back from there.
John Curry (Drift King) 928OC member Grand Prix White 1994 GTS AT (The GTS) Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz) |
WSM is "work shop manual"........
1956 Intermeccanica 356 Speedster (sold),1957 Intermeccanica 356 Speedster (sold),,1985.5 Porsche 944 (sold),1955 Thunder Ranch 550 Spyder (sold), 1955 Outlaw 356 Speedster (currently in build out), 1984 Porsche 928S (White), 1984 Porsche 928S (Red) |
SharkHead
The Ballast resistors (two of them) can be in white ceramic rectangular casings as Merlin mentions (like a few of my previous BMW's)...but on my rig they are cylinderical Black mounted in front of the coil on the fender wall. One for the Start circuit and one (with different resistance value) for the Run circuit; each has a wire to it and a wire from it. If no start and weak voltage the Start resistor may be bad.
Thanks everyone for your help. This gave me great ideas to proceed. Thanks again.
John
Petie3rd
did you ever get the engine running?
Troubleshooting Reference Base -
Like many threads - this one was simply left open ended with no reported results ?
It is always a pleasure to try and help a 928 owner breath life back into their car. As a rookie buyer about 10 years ago the Pelican Parts crew (and others) really came to my rescue many times as I worked out all the kinks in "Lady in Red (85) and then "Miss Purdy" (84). ![]() Michael
1984 928S - "Miss Purdy" 1987 911SC - "Frau Helga" 1986 930 - "Well Hung" 1975 911 Targa "Blue" Last edited by JK McDonald; 03-01-2018 at 07:51 AM.. |
