1985 Porsche 928s
Leaking exhaust
I suspect I have a small leak in my exhaust, where the LHS 4-into-one manifold meets the next section. These two sections are joined with a (sort of) triangular, three-bolt flange. Currently, there is a simple, thin flat triangular disc between the two flanges. Should I replace this with a crushable gasket? Is this a Porsche part or a generic part? Is there also a “donut” between the two flanges as well? If there is, should this also be replaced and is it a Porsche or generic part? Do you guys use exhaust paste in conjunction with seals / gaskets?
No paste. No donut.
I use Porsche gaskets, but generic would probably be okay if you can find the right size to fit.
John Curry (Drift King) 928OC member Grand Prix White 1994 GTS AT (The GTS) Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz) |
I cut my own gasket out of a sheet of exhaust gasket material given to me by an exhaust shop. No leaks.
