Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
chapstic2001's Avatar
Send a message via AIM to chapstic2001
Blown Turbo Preventing Startup
I picked up my 951 from the shop today and about a mile out from home I noticed some large white clouds after acceleration. About a week ago I saw a bigger pool off oil in the IC pipe than I had before so I was planning on replacing the turbo.
Well when I got the car home, I had to turn it off to get some work done and the garage cleared out. Now it won't start. Is it possible the turbo spit oil into the cylinders and it is mucking with the fuel delivery, preventing it from turning over?
'08 BMW e90 335i 6MT stock [aka 'take two']
'12 Dodge Durango [family hauler]
'86 951 (K&N Cone, Welt Chips, Tial, Zeitronix, P&P O-ring PH Head, WFHG, AFPR) [in storage]
Old 08-07-2018, 09:40 AM
A domestic car buddy of mind suggested that oil could have fouled up the plugs. I may get a cheap set, turn the car over w/o plugs to get any access oil out, put the new plugs in and give it a run.
Old 08-07-2018, 10:16 AM
soxnail's Avatar
If plugs are fouled, clean them acetone and try again instead of buying another set.
Sox
"Little problems always come back and bring bigger friends with them".
1986 951"MADDOG" black with maroon interior
All stock with shimmed WG
Old 08-10-2018, 08:52 AM
I picked up another set and installed them today...same no start result. Good times. For good measure, I ....
Made sure the crank sensors were not somehow disconnected.
Confirmed I am getting spark
Confirmed I am getting fuel [in fact, I looked at the plugs and they didn't look too bad]
The tach is fluttering when I try to start it
Old 08-10-2018, 11:52 AM
soxnail's Avatar
How did you check for spark and fuel ?
Sox
Old 08-12-2018, 08:21 AM
Super Moderator
nize's Avatar
any blink codes?
Blink Code Tester queston...
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 08-13-2018, 07:05 AM
Do compression test...
Old 08-23-2018, 03:36 PM
