Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Rattling exhaust manifold I think?
So I was driving my car home from the auto part store about to do an oil change when I started to hear a rattle I was only a mile away from home when it started so I just drove home I located the sound of what I believe is the rattle my exhaust manifold on the one closest to the front of the car is only held on with 1 bolt the other I don't know where it went. I've only owner the car for about a month now and was wondering if this could be the cause of the rattle.
Old 09-15-2018, 03:34 PM
soxnail's Avatar
Hi welcome to the joys and sorrows of Porsche ownership.
You need to indicate what type and model your car is....that said normally there are 2 studs or bolts holding each exhaust manifold inlet.
Sox
"Little problems always come back and bring bigger friends with them".
1986 951"MADDOG" black
Dual port WG, 4 port control valve with EBC
Old 09-15-2018, 05:16 PM
It is a 1987 Porsche 944s
Old 09-15-2018, 07:29 PM
In the Fires of Hell.....
kdjones2000's Avatar
You will do better to post in the other 944 forum. This one is dedicated to the Turbo model.
That being said, you should have 3 nuts/bolts per exhaust manifold outlet on the 944S model.
Your studs may have broken off, and you will need them replaced. Do you smell exhaust in the cabin while you are driving the car now?
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 09-15-2018, 08:50 PM
soxnail's Avatar
Keith you beat me to it
Sox
Old 09-15-2018, 09:11 PM
Alright I believe just one of them fell out/off would you happen to know the bolt size and thread?
Old 09-15-2018, 09:58 PM
Should be M6x1.5mm, but removing a broken stud is not trivial.
Old 09-16-2018, 05:28 AM
soxnail's Avatar
M8 1.25 in my 951......
Sox
Old 09-16-2018, 06:33 AM
