Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
soxnail's Avatar
Random musings
I was fixing the fuel gauge, which was offset by a 1/4 tank. In the pic you can see it goes way below empty.
I saw the non populated lamp spots in the instruments cluster board.
Upon illuminating the cluster by shining a light through the empty sockets I discovered that one of them had an indicator glass in front that had CHECK and an engine symbol in it in red. So the thought is, I have a blink code led in my glove box, I could move it to the empty socket in the instrument cluster and get the blink code to not only be visible without opening the glove box, but actually have a check engine symbol flashing in front of me.
What say you ?
Sox
"Little problems always come back and bring bigger friends with them".
1986 951"MADDOG" black
Dual port WG, 4 port control valve with EBC
Old 09-18-2018, 09:13 AM
In the Fires of Hell.....
kdjones2000's Avatar
I too have looked at the "options" available in those unlit sockets.
Sounds like a lot of work for not much gain...
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 09-19-2018, 06:08 AM
soxnail's Avatar
Well I already have the wiring done...if you look at my old thread "DME hacks".
My thinking was that a blink code in the instrument cluster would catch my eye a lot easier than having it in the glove box.
Sox
Old 09-19-2018, 10:58 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
When the tank is full does the gauge show "full"? I have found that if you look at the gauges page in the owners manual, it shows what those needles' positions on each gauge should look like with the power off. If your needles aren't in those positions, simply expose the Gauge face and move the needles on the shaft until they agree with the owner's manual presentation. With all the miles you have on your gauges, I'll bet several don't sit right.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 09-19-2018, 02:35 PM
soxnail's Avatar
Thanks fixed now.
I actually hold the round black disk behind the gauge needle and move it to the proper position, as this eliminates my fat fingers bending the needle itself.
Sox
Old 09-19-2018, 03:17 PM
