Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
I was just going over some of the car, to get part # and noticed. that the rear trailing arm on the car, is for an 87 turbo late offset # 951.331.513.4r. am i wrong or is that the right trailing arm for my car. If so how do they have early offset wheels on them. Picture of trailing arm is above. Thanks
Old 10-09-2018, 12:23 PM
On the front suspension, the upper strut mounts are different between 86 and 87. Learned that the hard way when I upgraded my 86 turbo to late offset.
Old 10-10-2018, 08:10 PM
In the Fires of Hell.....
kdjones2000's Avatar
That is a casting number, not a part number. It does not show up on PET.
The actual PN's are:
951.331.021/022.01
M030: 951.331.021/022.31
but don't expect to find these stamped onto the trailing arms anywhere.
So according to PET, the trailing arm is the same for both early and late offset cars. The difference is in the hub/spindle apparently.
So for the rear, other than the torsion bars, you will need late offset axles/hubs, plus rotors and of course turbo calipers.
There will likely be some other minor things, but that is what PET shows.
NASA/PCA Instructor
'88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
1987 924S 944 SPEC racecar - '88 pistons/DME, short 5th
1987 944S - Restored salvage title, ready to live again
Old 10-11-2018, 08:29 AM
Thank you for the help
Old 10-11-2018, 02:45 PM
