944 addict
Driveline rattle
I have a rattling noise coming from transaxle area but only when the trans is in neutral. When I had the trans out for output shaft seal replacement there was no indication of pinion shaft seal leakage.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
In the Fires of Hell.....
Very normal on these transaxles.
From what I have read, it's the 5th gear making the noise. Nothing to worry about, but it's a bit annoying I guess.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
944 addict
I just checked under the car to verify there's no leaks from the transaxle because I replaced a defective oil cooler and output shaft seals and it's dry so I can at least drive it but you're right, it is annoying.
