Turbo S
Is it possible to convert a K26/6 to a /8.. Is the only diffrence the hot side.
If it is what else uses that size hot side so I know what to look for. Thanks Patrik
1987 944 Turbo (converted) |
Yup only difference.......
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
Where does one purchase seals and bearings for turbochargers? Mine has about 70K miles on it. Sooner or later it's going to have to be rebuilt. It's a K27dr from PowerHaus.
Lawrence 1986 951 2002 SLK32 AMG 1987 328GTS 2011 528i |
What else uses a turbo with a #8 hotside??
Maybe I could find one that needs rebuilding for a good deal.. U never know ![]()
Lawrence-
I am looking for the same thing. I checked out some posts on other sites and it sounds like rebuilding a turbo is pretty easy. I have a K26/8 from my friend's turbo S with 150K miles on it and want to rebuild it and put in on my 86 with some larger injectors. Anyway, it sounds like there are kits out there that consist of bearings and seals for around $125. If the turbo isn't damaged and just worn out, the rebuild is a no-brainer. Check out this site... http://www.turbocompressori.net/turbochargers_parts.htm -g
Geoff Baltz - St. Louis Region PCA Board Member/DE Chairman PCA HPDE Instructor |
car lover, work in www.sacer-shop.com |
In the Fires of Hell.....
Only 12 years late, bonnie sacer..... Oh my.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
