Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Flywheel lockout tool play
Hi,
I am replacing the belts and water pump on my 1987 944 turbo and i installed the lockout tool and just to check if it is installed right i turned the flywheel and it had about an 1/2inch of play at the flywheel mark. Is this normal or did i do something wrong.
Thanks cory
Old 11-26-2018, 06:01 AM
In the Fires of Hell.....
kdjones2000's Avatar
You did something wrong.
NASA/PCA Instructor
'88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
1987 924S 944 SPEC racecar - '88 pistons/DME, short 5th
1987 944S - Restored salvage title, ready to live again
Old 11-26-2018, 11:22 AM
Yes, something is wrong, there shouldn't be any play.
review these instructions: https://www.pelicanparts.com/techarticles/Porsche_944_Turbo/51-ENGINE-Flywheel_Lock_Installation/51-ENGINE-Flywheel_Lock_Installation.htm
Verify the following:
You have engagement between the tool and the starter ring gear. Make sure the lock isn't installed upside down.
Your starter bolts fit well with the flywheel lock.
Your bolted tight.
1960 356 Super 90 - EFI'd
2017 Focus RS - Daily
Old 11-27-2018, 07:14 AM
Thanks for all the help. Found out the tool wasn't pushed up into the teeth enough.
Old 11-30-2018, 11:32 AM
