Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
951 Vacuum line from brake booster?
Hi guys,
So I am finishing up replacement of speed/ref sensors and am trying to put this thing back together.
There is a small vacuum line coming from the brake booster line to intake that got ripped out accidentally when I was moving the hose around to get access to the ref sensor bracket.
I can't seem to figure out where the two unconnected ends are supposed to go - anyone have any insight?
Old 08-09-2019, 09:50 AM
In the Fires of Hell.....
kdjones2000's Avatar
The one with the plastic tube on it should go down to one of the taps going into the HVAC system. Look down below all of those wires, right next to the firewall. Hard to see, hard to get to.
The other end should go the vacuum reservoir bottle next to your battery. You should have another plastic tube going from that out through the firewall to your "T".
Good luck...
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 08-09-2019, 10:31 AM
Thanks much - with your description I found out where I needed to make my connections - all back together now, thanks again!
Old 08-09-2019, 03:14 PM
