Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Parts list to have ready for turbo swap?
I will be swapping in a new turbo and am sure some bolts, etc. will break, etc. Looked around but couldn't*find a list of "you will definitely need these parts" or similar..
What I have so far that I need to order are:
- Turbo oil line crush washers
- Turbo oil line O-Ring
The turbo is not water cooled so will need some parts to address that as well I am sure...
What bolts, studs, etc. should I have ready on hand?
I already have AOS seals ready.
Thanks!
Old 08-13-2019, 01:32 PM
In the Fires of Hell.....
kdjones2000's Avatar
Get this:
http://rennbay.com/Hardware/944-Turbo-Exhaust-Hardware-Kit.html
NASA/PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
1987 924S 944 SPEC racecar - '88 pistons/DME, short 5th
1987 944S - Restored salvage title, ready to live again
I can fix your late 944 Cruise Control module - PM for details
Old 08-13-2019, 03:39 PM
I also suggest you read up on how to remove those turbo mounting bolts.
If you mess it up, you are going to be in a world of hurt...
Old 08-14-2019, 07:36 AM
Super Moderator
nize's Avatar
i second this, especially the long bolt. the best method i've found so far is to put the tool (wrench, ratchet, whatever) on a jack, and jack it up so it's almost supporting the weight of the car on that bolt before trying to break it loose by tapping with a hammer. of course you'll want to thoroughly soak that bolt with pb-blaster overnight and tap it several times with a hammer to get it as loose as possible well in advance of attempting to unscrew it.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 08-15-2019, 10:31 AM
Thanks!!!
Fingers crossed
Old 08-15-2019, 01:38 PM
