-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   WG tests (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/1048045-wg-tests.html)
Spencan 11-19-2020 12:47 PM
Sox, if you need more stock wastegates to play with, let me know. I have 2 of them sitting in my garage right now.
soxnail 11-20-2020 07:50 PM
Spencan thanks, will do.
Sox
nize 01-14-2021 07:01 AM
hey sox i was digging through old posts and found this relevant one to what you are doing here:
http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/380686-one-best-mods-i-have-done.html
which was linked from this one (and has another link):
http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/389978-tail-vs-lr-dual-port-wastegate.html
just trying to keep everything in one place so it's easier to find in the future.
soxnail 01-14-2021 08:27 AM
Thanks Nize, I already saw the above threads...
I am now working on the tial gate. Need to fab some parts, but first I need to convert my el cheapo AC welder to a Dc welder.
Sox.
http://forums.pelicanparts.com/uploa...1610645209.jpg
Mike Goebel 01-15-2021 02:37 PM
Freaking Sparkys!
Mike G.
soxnail 01-17-2021 07:41 AM
nutty boltheads ? :)
soxnail 01-21-2021 09:27 AM
Ok welder converted and parts fabed....
http://forums.pelicanparts.com/uploa...1611253567.jpg
soxnail 02-08-2021 10:14 AM
Got the new waste gate installed. With the new electronic controls...
Test run:
The orange line is "Boost On" this is the command from the KLR and the new electronics to the 4 port valve.
http://forums.pelicanparts.com/uploa...1612811487.jpg
nize 02-08-2021 01:57 PM
100.2 percent boost! doesn't that violate the laws of physics or something? or is your welding that amazing? can you weld a sway bar bracket for me?
soxnail 02-09-2021 05:49 AM
Nize it's a on off signal so boost on or off...the number is just an indicator. So high number is on low number is off.
I could try, my welder is a low power el cheapo so welding any thing thicker than 0.25" is iffy. If want me to send it to me. Pm me.
Sox
soxnail 05-10-2023 10:50 AM
So on this old mater...
Here is my turbine inlet to MAP pressure ratio.
line 1 is before getting on the throttle .
Line 2 is map is at atmospheric, notice the ratio dropped to little over 1:1. It was as high as 9 when the car was in vacuum.
Line 3 is 100% throttle. Ratio is about 1:1.5
Line 4 is getting to full boost, ratio is about 1:2 it stays there for the whole period till I got off the gas.
Line 5 is back to idle.
Time ticks in the x axis are 0.1sec (100ms).
Pressure is in KPA on the y axis.
EXP is turbine inlet pressure.
Sox
http://forums.pelicanparts.com/uploa...1683744174.jpg
soxnail 05-10-2023 11:35 AM
Rethinking the above, I should use the pressure at the banjo bolt rather then the MAP.
Sox
soxnail 05-15-2023 12:04 PM
Sorry wrong info was posted will do again.
Sox
nize 05-19-2023 10:37 PM
are you using the stock BOV? maybe that opened up.
soxnail 05-20-2023 11:16 AM
Thx Nize,
running an aftermarket aluminum Diverter.
Checks out. Holds vacuum 22 in for multiple hours. Pressure side holds 20 psi with about 15 or so psi on the sense tube. Releasing the pressure on the sense tube vents the pressure side with a big whoosh.
Still looking ....
Sox
soxnail 05-20-2023 12:07 PM
Removed the graphs from the above post as the ratio graph was incorrect
Sox
soxnail 05-20-2023 01:30 PM
Ok let me try again...
http://forums.pelicanparts.com/uploa...1684617600.jpg
The Loss in the IC and throttle body (Mloss)appears to be about 2.5 psi (17KPA).
The output from the Turbo levels off (TRB), but the exhaust pressure (EXP) continues to go up??
The exhaust to turbo outlet ratio is around 1:2.5 when the boost from the turbo levels out, but as the exhaust pressure keeps going up with no further increase in boost the ratio gets as high as 1:3.
I don't quite understand why the turbo's output is nice and smooth (TRB) the Manifold pressure seems to be jumpy (MAPc) ??
Any comments enlightenment would be welcome.
Thx Sox
nize 05-20-2023 02:56 PM
i'd think the exhaust continues to climb because the RPM increases.
soxnail 05-22-2023 08:30 AM
Would that not also increase the turbo's output too?
nize 05-24-2023 08:46 AM
no, otherwise it will explode. :)
the turbo is probably hitting its max output so it's done. time to get a bigger turbo!
soxnail 05-25-2023 06:01 AM
Yah, I was only referring to the rise in exhaust pressure at the last part of the graph without a rise in the turbine output. As the exhaust pressure is still going up, it probably means that the WG did not open yet....
Sox
nize 05-25-2023 07:22 AM
that could also be the back pressure caused by the restriction in the turbine itself.
soxnail 06-18-2023 02:49 PM
So the car is growing sensors like weed...
Results of the last run with MAP, Compressor outlet to inter-cooler, cross pipe to turbine inlet and turbine outlet to the exhaust all being monitored.
Points of interest:
-Boost as seen in the Manifold goes to about 12 psi and holds pretty steady till I got off the gas.
-Compressor outlet pressure to inter cooler at the banjo bolt showed that the the plumbing eats up about 2 psi.
-Back pressure in the exhaust was as high as 3.5 psi, that surprised me, I expected my exhaust to flow more freely.
-Pressure at the turbine inlet as seen in the cross over pipe got up as high as 45 psi, seems excessive to me ??
I have not done the ratios yet as I am still trying to figure out which formula to use.
The one for pressure ratio to calculate the turbo charger is pretty straight forward, but the the expansion ratio for the turbine and the efficiency for the turbo out (boost) vs. pressure at the turbine inlet is more involved.
Any words of wisdom would be appreciated.
Thanks Sox.
http://forums.pelicanparts.com/uploa...1687128493.jpg
soxnail 07-09-2023 04:33 PM
No words of wisdom ???
Does any one have any data on back pressure in the exhaust ?
3.5 psi seems pretty high.
Thx Sox
nize 07-13-2023 10:41 AM
i'm not sure anyone has extensively measured the turbo back pressure and exhaust pressure but i do recall what was important was the boost vs. back pressure ratio. it looks like you have around 3:1 ratio which does seem a bit high but not excessive.
soxnail 07-13-2023 12:15 PM
Thanks Nize,
I am wondering how much of th 45 + psi I see in the Hot side inlet is due to the 3.5 psi on the outlet of the turbo.
The turbo spins freely and there is no play in the turbine spindle.
No damage that I can see in the compressor wheel. It should be good for 15+ psi (K26 #6) original.
Interesting side note I am in Crested Butte CO. It takes 4 psi on the boost before the car's gauge shows 1 bar. I am at 11000 ft.
Thx Sox
soxnail 12-30-2023 12:36 PM
So further on this...
Putting the 3 inch exhaust fixed the back pressure in the exhaust issues, it is negligible now. Also my back pressure at the turbo went down. The ratio now stays at 1.5 or so.
Couple of interesting observations.
When I test with just the spring (10psi) and no control from the boost controller allowing the exhaust to push open the WG I got the following. The y axis is KPA and the x is 100ms each. Notice the exhaust back pressure and the boost are almost 1:1. the range is 3k rpm to 5k.
http://forums.pelicanparts.com/uploa...1703971122.jpg
The second pic shows the same as above but with the boost controller always allowing full boost pressure to the top of the WG, so it should be spring + the boost holding the gate. The net gain is about 1.3 psi, but the back pressure goes up quite a bit. Also the boost peaks at about the same spot.
http://forums.pelicanparts.com/uploa...1703971346.jpg
Finally the last one is with the boost controller modulating the WG at a15hz PWM. There does not seem to be any obvious difference.
http://forums.pelicanparts.com/uploa...1703971627.jpg
So as the turbo should be able to produce more boost than 11psi or so it is showing I think either the gate is leaking (but then why the increase in back pressure with no increase in boost ?) or the turbo is petering out ?
Will try to close off the WG manually and try VERY BRIEFLY to see if I get more boost.
Sox
nize 01-02-2024 08:04 PM
maybe your BOV is leaking boost? time to get a billet aluminum BOV! arr! arr!
nize 01-02-2024 08:13 PM
by the way, i'm glad the 3" exhaust fixed your original backpressure issue. did you figure out if the original exhaust was collapsed on the inside?
soxnail 01-03-2024 09:59 AM
It was not collapsed, but had some serious dents that restricted it.
Sox
soxnail 01-03-2024 10:01 AM
Yup already use one :)
The issue was the ICV, so will post on that old thread.
Sox
http://forums.pelicanparts.com/uploa...1704308456.jpg
nize 01-03-2024 10:48 AM
FYI i've reversed the billet BOV orientation (boost enters on bottom, releases through side) so that spring + boost pressure holds it shut, so in case the control line fails it will always open.
Molton 01-05-2024 11:27 PM
Pressure-ratio between turbine-inlet and intake-manifold boost-pressure is not direct or linear. At low-RPM and low boost-levels, ratio will be < 2:1. At high-RPM and high-boost, it will be > 2:1. Also varies by turbine-size with larger TurboS K26/8 turbos operating at lower ratios than K26/6.
soxnail 01-08-2024 07:35 AM
Yup I see that..
Thanks Sox
