Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
rufrob's Avatar
Rear end binding or slop
Happy 2020 to all.
I wish you all happy/trouble free motoring.
I did the clutch on my 86 last summer. I donít drive the car. While moving it recently it feels like the right rear is binding. I hear a thump when the clutch engages for forward motion not rear. When I put the car on jack stands the noise and feeling is gone and the rear wheels both spin freely in and out of gear and by hand. Parking brake holds and releases.
I checked the cv joints are torqued and no unusual slope in the transmission.
I changed the clutch due to chatter in reverse which was caused by a lip worn onto the guide tube.
I did some searches which donít match my symptoms.
Could it be the transmission mount?
Thanks.
Never give up
Old 01-13-2020, 03:47 PM
Super Moderator
nize's Avatar
it sounds like it could be the transmission mount and/or the cv joint. you can check for play in the cv joint by moving the shaft by hand. the transmission mount is tough to check as the clearance is very tight above the transmission but you might be able to squeeze a mirror up there. i suppose you could try shaking the transmission for play.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 01-14-2020, 09:45 AM
CBerry
Sounds like metal fatigue in the outer CV joint. Not hard to fix and parts are here from Pelican.
Old 01-14-2020, 07:51 PM
rufrob's Avatar
Sorry canít recognize the photo
Never give up
Old 01-15-2020, 01:17 PM
Super Moderator
nize's Avatar
the photo shows the inner race of a disassembled cv joint. you typically replace the entire joint, the part is here:
https://www.pelicanparts.com/More_Info/95133290100M60.htm?pn=951-332-901-00-M60&bt=Y&fs=0&SVSVSI=1026
Old 01-15-2020, 08:54 PM
