Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Originally Posted by nize View Post
944online makes a short shifter that looks like it replaces the entire linkage, and will probably remove the shift slop, it also looks like it can be installed to preserve the factory shift throw as well as a short throw option:
https://944online.com/index.php/short-shifter.html
Interesting?? The 944online one looks like the older version of the only 944 one.
https://www.only944.com/partscatalog/only/shortshifter/
Mike G.
Old 03-24-2020, 01:23 PM
soxnail's Avatar
Thanks Nize:
Transmission oil will be done...
Looking at the seal and shifter now.
Sox
"Little problems always come back and bring bigger friends with them".
1986 951"MADDOG" black with maroon interior
All stock with shimmed WG
Old 03-24-2020, 02:52 PM
I like your clutch bearing extractor. John
Old 03-24-2020, 06:42 PM
Super Moderator
nize's Avatar
it looks like the 944online kit has two holes so it can be used as a stock shifter (only side/side movement) or a short shifter, while the only944 has one hole and can only work as a short shifter with 30% reduction in both front/back and side/side throw.
i'm curious if the 944online kit can preserve the factory throw.
i haven't used either, maybe contact both and ask for details?
also, it looks like that plastic link block is available as a complete shift linkage set, part number 94442401302 for $256. ouch.
https://www.pelicanparts.com/cgi-bin/ksearch/PEL_search_2016.cgi?command=DWsearch&description=9 4442401302
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 03-25-2020, 07:01 AM
soxnail's Avatar
Thanks jjeffries,
necessity must when the devil drives.....
Sox
Old 03-25-2020, 07:11 AM
I think its an old version of the only944 part. Here's a pic from the only944 site. In this pic it looks like they haven't installed the later version with only one slot.
Also the front to back distance doesn't change with an increased slotted arm length. That's controlled by the other arm on the shaft.
Mike G.
Old 03-25-2020, 10:18 AM
soxnail's Avatar
I did the ultimate lightning mod to my transmission, it was lightened by at least 15 lbs...
Cleaned of 30 years of grease and dirt build up
Sox
Old 03-25-2020, 04:12 PM
Sox
Be careful I'm sure there's someone on here that will recommend against that !
Mike G.
Old 03-25-2020, 06:58 PM
soxnail's Avatar
Yah it may have been the only thing holding it together..
Sox
Old 03-26-2020, 08:06 AM
MY new trick for cleaning heavy stuff like that is, W40 a few times for a day or more then ZEP FAST 505 and a pressure washer. And of course a bunch of different brushes.
Mike G.
Old 03-26-2020, 09:56 AM
soxnail's Avatar
W40 = wd40 ??
Old 03-26-2020, 05:12 PM
W40 = wd40 ??
Yeah!! haha
Mike G.
Old 03-26-2020, 06:49 PM
soxnail's Avatar
A pic of the old flywheel and pressure plate the damage is very evident in the PP.
Sox
Old 03-27-2020, 01:08 PM
In the Fires of Hell.....
kdjones2000's Avatar
Time for some machine work:
NASA/PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
1987 924S 944 SPEC racecar - '88 pistons/DME, short 5th
1987 944S - Restored salvage title, ready to live again
I can fix your late 944 Cruise Control module - PM for details
Old 03-29-2020, 11:55 AM
soxnail's Avatar
KD everything but the flywheel and throw out bearing fork is being replaced..
Still trying to find a machine shop locally that A, does resurface using a flywheel grinding machine. B, does not give me a blank look at the "can you balance the flywheel and PP as an assembly" question.
Sox
Old 03-29-2020, 01:31 PM
soxnail's Avatar
After pic of the transmission, for before see the "don't need no stinken transmission jacks" post:
Any snide remarks will get you a one way grey hound ticket (third class) to come down here and help clean.
Sox
Old 03-29-2020, 01:34 PM
soxnail's Avatar
I have a PP that is in good shape, needs to be resurfaced. I am putting in a new one so if any one wants it, its your for postage.
Sox
Old 03-29-2020, 05:24 PM
Make it first class and I'll bring my pressure washer!
Mike G.
Old 03-29-2020, 06:51 PM
Super Moderator
nize's Avatar
sox are you going with the awesome KEP aluminum pressure plate or some other pp?
Old 03-30-2020, 12:14 PM
soxnail's Avatar
Nize I did call them, but could not get someone the phone who knew what I was talking about. So I wussed out and ordered a 951-116-023-01 standard 951 plate
Sox
Old 03-30-2020, 01:58 PM
