Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
There is no substitute..
FRZ951's Avatar
Thumbs up Door Handle Removal - Write-Up w/ Photos
During my actual project, I had to search for the door handle removal. I found some good stuff on Clark's Garage and also on PelicanParts, but they are pretty straight forward. Some details aren't shown, and many of us have hard time when come the time to install the door handle knuckles.. But there is the easy way. It is a little bit longer but you will be sure to not break anything, and the install will be smooth. So I decided to write my own to help you guys.
Tools:
  • Philips head screwdriver
  • Medium and Long flat screwdriver
  • 8mm socket
Step 1:
Step 2:
  • Remove the clip and the little shaft
Step 3:
  • Using the 8mm socket, remove the 3 screws to remove the plate behind the Power Lock Actuator, then slide down the plate
Step 4:
  • To have access to the Door Handle Knuckles, we have to remove the Power Window Guide. Removing this guide is the secret to make this work easy.
  • To remove it, simply unscrew this little boy down there with the 8mm socket, then slide down the guide. Sometimes you have to jiggle-wiggle a little but go carefully to be sure to not break or pry something. Normally this should be easy to remove.
View 1
View 2
  • Now you have access to the Door Handle Knuckles as shown. We will pop them out later.
Step 5 on the next post as we are restricted to 12 images by post.
--Matt
I couldn't find the sports car of my dreams, so I built it myself
Porsche 951 1988 - More than 305 RWHP & 350 RWTorque
Old 04-27-2020, 06:22 AM
FRZ951's Avatar
Step 5:
  • Unscrew the Door Handle lock.
Step 6:
  • Slide the door towards the front of the car to unblock the handle.
  • Then partially bring out the handle, just enough to see the mechanism.
Step 7:
  • With the medium long flat head screwdriver, gently pop out the white transparent knuckle. If the image isn't clear enough, you can look at the other side, or the last image in the previous post.
Step 8:
  • With the long flat head screwdriver, gently pop out the other knuckle which is located inside the door. I use the door panel as leverage to help to pry.
Step 9:
  • Disconnect the door handle mechanism wire ;
  • Remove the wire from the plastic clip ;
  • Remove the handle from the door.
That's it!!
Installation is reverse.
--Matt
soxnail's Avatar
Very nice thanks, I am about to fix the power lock system. It works fine with a key (both doors lock and unlock) but if I use the switch in the car it just clicks and won't lock. In 4 tries it might work once. Unlock always works.
Sox
"Little problems always come back and bring bigger friends with them".
1986 951"MADDOG" black
Dual port WG, 4 port control valve with EBC
Old 04-27-2020, 06:37 AM
Super Moderator
nize's Avatar
thanks for the nice write-up. i've added to the 951 reference page.
i have to replace the door hinge, and can't figure out how to access the bolt behind the body, but that's a different job.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 04-28-2020, 11:27 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
I just finished recovering from repairs of damaged door lock/opening mechanisms during post paint reassembly of everything. The locks were so screwed up, I ended locking my self out of the car and had to enter through the rear hatch. Bottom line, I rebuilt, cleaned and lubed all the door opening and locking mechanisms and replaced the door opening links (which the shop damaged) and the weathered upper window channels. This was another learning experience and another major PITA and now I get to finally drive my 5 year restoration project of my '86 951.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 05-02-2020, 05:33 PM
Tags
door handle , porsche 944
