ID this turbo
I know its a KKK k26...but be nice to know what the other numbers are.
Thanks Sox ![]()
"Little problems always come back and bring bigger friends with them". 1986 951"MADDOG" black Dual port WG, 4 port control valve with EBC |
Super Moderator
that 85 looks like the manufacture year followed by the serial number. the third line represents the internal cartridge since the k26 housing is available with multiple interchangeable internal configurations.
found this reference googling around: 951s (s2) - k26/8 K26-2670GGA 8.11 5326 970 7041 5326 150 0020 Bearing housing (water-cooled) 5326 120 5002 turbine Shaft and wheel 5326 120 2119 turbine Shaft and wheel 5326 100 7320 Turbine housing 5326 151 5713 Compressor backplate 5326 151 5710 Compressor backplate 5326 123 2201 Compressor wheel 5326 123 2022 Compressor wheel 5326 101 5213 Compressor housing 951 (s1) -- k26/6 K26-2667GA/6.92 5326-988-6720 5326 150 0020 Bearing housing (water-cooled) 5326 100 7311 Turbine housing 5326 120 5004 turbine Shaft and wheel 5326 120 2110 turbine Shaft and wheel 5326 151 5704 Compressor backplate 5326 123 2039 Compressor wheel 5326 123 2015 Compressor wheel 5326 123 2020 Compressor wheel 5326 101 5234 Compressor housinq 5326 101 5202 Compressor housinq 931 s2 K26-2660 GA 4.10 5326-970-6022 5326 150 0011 Bearing housing 5326 100 6329 Turbine housing 5326 120 5002 turbine Shaft and wheel 5326 120 2107 turbine Shaft and wheel 5326 120 2119 turbine Shaft and wheel 5326 151 5701 Compressor backplate 5326 123 2036 Compressor wheel 5326 123 2007 Compressor wheel 5326 123 2017 Compressor wheel 5326 101 5104 Compressor housing 5326 100 5104 Compressor housing 931 s1 K26-2664G4.10 5326 150 0011 Bearing housing 5326 100 6329 Turbine housing 5326 120 5002 turbine Shaft and wheel 5326 120 2107 turbine Shaft and wheel 5326 120 2119 turbine Shaft and wheel 5326 151 5701 Compressor backplate 5326 123 2035 Compressor wheel 5326 123 2006 compressor wheel 5326 123 2016 Compressor wheel 5326 101 5103 Compressor housinq 5326 100 5103 Compressor housinq some reference on the audi site: http://www.sjmautotechnik.com/trouble_shooting/turboparts.htm here's a similar part on autobahn: Autobahn Parts - Engine, Porsche 944 Turbo 951 OEM KKK K26 Turbocharger, 5326 970 6720, 85 743 0841
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
Yah I saw these references too...Non appears to be quite my turbo.
Sox
Got turbo out...what a royal PITA.....
The bottom of the turbo bolt is not an allen screw but a torx screw, so I stripped it with an allen head. Had to take the sway bar off and the steering rack to get the stupid bolt out. first pic broken stud. ![]() Second pic shows the other stud , looks like the section that is in the flange is worn off ??? Sox
More pics of the turbo..
Mike G. |
Mike you got a contact name there ?
Sox
Thanks Mike.
Well got two of the studs out of the turbine to exhaust housing. The other two sheared at the surface. 2 days of PB blaster and heating to red hot and back got 50% results... Need to buy another set of drill bits. Sox
Super Moderator
you just reminded me of another reason i gave up and just bought a new turbo.
Nize where is the fun in that ??
![]() BTW what is the model # of your turbo ? Sox
sheared studs drilled out, chased the threads with a 10 X 1.5 tap.
Sox
