Well how do you do that?
Mike G. Last edited by Mike Goebel; 04-03-2020 at 12:20 PM.. |
In the Fires of Hell.....
Go "advanced", and it will be available.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
I don't think I could find the right button to press even if you took control of the mouse.
![]() Mike G. |
Mike "edit" and then delete the post...If first post, it should delete the thread. If not it will blank it out and you can put an edit reason as removed by thread starter.
Sox
"Little problems always come back and bring bigger friends with them". 1986 951"MADDOG" black Dual port WG, 4 port control valve with EBC |
![]() HAHAHA I give!! Mike G. |
